snap oversteer?
Old Jun 6, 2003 | 01:28 AM
skunks's Avatar
I'm a CF and poop smith
snap oversteer?
ok, I have heard alot about snap oversteer which seem affect fd's in particular and was wondering what this term really ment.
P.S. not sure if this should be in the race section or what so please feel free to move this thread around
Old Jun 6, 2003 | 02:04 AM
DeNguyen's Avatar
http://www.seansa4page.com/resource/steering.html
i have not idea what the SNAP is for. maybe when we try to correct the oversteer, it is very snappy and the car tends to over-correct itself?
Old Jun 6, 2003 | 03:53 AM
skunks's Avatar
i know what over steer and under steer is, i just dont understand what people say by snap oversteer occuring a lot in fd's
Old Jun 6, 2003 | 04:07 AM
ludeowner's Avatar
You know how when you induce oversteer with the throttle and steering, and the moment you let off the gas and straighten steering the car snaps back (or jerks back) in the opposite direction just a little and then it goes straight again.
When I first got my FD, I managed to oversteer it and induce about 20 degrees of yaw away from the direction I really wanted to go. When I let off the gas, the car snapped back right away and the nose went towards the direction I wanted it to go.
Old Jun 6, 2003 | 04:59 AM
maxcooper's Avatar
WWFSMD
"Snap" just means "quick" and often "surprising, oh ****!" and sometimes "surprising, oh ****! CRUNCH!". The car will rotate quickly when you unload the rear end.
-Max
Old Jun 6, 2003 | 05:29 AM
skunks's Avatar
what causes this? is this just becuase we over correct too much or just release the gas when we are suppose to stay on it?
Old Jun 6, 2003 | 06:26 AM
Alien7's Avatar
both.
Old Jun 6, 2003 | 01:23 PM
maxpesce's Avatar
Ex fd *****
-Max
Or even, slide, lift, surprise, oh ****, WOW now I am going around the other way for a full 360
Old Jun 6, 2003 | 01:49 PM
rynberg's Avatar
I think you have to be doing something wrong to get this car to "snap oversteer" in any type of street driving on dry roads. Everytime the rear has come out on me, it has been predictable and easy to catch. On a tight auto-X cross, it was the same.
On a road racing track with a modified suspension and/or way more power than stock, I suppose it may be easy to get the rear to step out hard and fast.
Old Jun 6, 2003 | 04:28 PM
potatochobit's Avatar
it happens. made me actually way oversteer and hit the curb. i HATE it. i heard the toe links help stop this.
Old Jun 6, 2003 | 04:46 PM
maxpesce's Avatar
Ex fd *****
Originally posted by rynberg
I think you have to be doing something wrong to get this car to "snap oversteer....
True In my example I was on the track and my bad instintcs (first timer) made me LIFT & Countersteer when I should have just countersteered.
from my previous post-
"slide, LIFT , surprise, oh ****, WOW ...."
_____ ^^ ________
WRONG
Old Jun 6, 2003 | 05:17 PM
cavellm's Avatar
I think driving slower through turns would help stop this.
Old Jun 8, 2003 | 12:04 PM
pedalpusher's Avatar
I've noticed a tendency toward trailing throttle oversteer, but my car's always been pretty polite about it.
pedalpusher
Old Jun 8, 2003 | 01:18 PM
r0gu3's Avatar
Boostless FD
I use it with feints to induce drifts.
Old Jun 8, 2003 | 02:20 PM
1st to 3rd's Avatar
IMO, the FD is predictable and easy to catch in most cases. If you want experience some snap oversteer, try a FB. The rear hangs out a little bit then it's gone.
Old Jun 8, 2003 | 03:24 PM
skunks's Avatar
hmmmm, I dont think i have ever experience snap oversteer in my car then. I use to think that it was when you over countersteer in a slide and the car snaps back the other way (especially when you dont put enuf throttle and the rears grip again suddenly). In anycase, has anyone ever actually experienced this in a FD? When ever I drive, I pretty much know if I'm gonna loose it or not via doing thing which would actually make it do so such as clutch kick, clutch drop, power over, feint, hard braking or whatever other technique which would get the rear out. I think the only way to get the car to do this snap oversteer would be if you came in to a corner way too fast or trailbraked in to it and then lost it (things that newbie's do or other thing we do when we over estimate our cars).
Old Jun 8, 2003 | 03:42 PM
cavellm's Avatar
What is feinting?
Old Jun 8, 2003 | 09:27 PM
SteveF's Avatar
I've seen a lot of snap-oversteer discussions in the MR2 market. The guys will not be speeding, and be driving on wet roads and wreck. The situation is usually the rear end unloads, and when it does, it steps out very quickly, catching the driver unaware. This leads to a spin. There are a lot of guys that have quite a bit of driving experience and still have this happen to them.
The mid engine format causes this problem to be worse due to the fact that the majority of the mass of the car is near the center of rotation.
I don't think FD's have snap oversteer, but I could be wrong.
Old Jun 9, 2003 | 02:23 AM
doncojones's Avatar
I've heard that slop in the rear suspension due to worn out bushings can sometimes cause it to get a bit unpredictable.
Old Jun 9, 2003 | 02:56 AM
skunks's Avatar
Originally posted by cavellm
What is feinting?
http://www.driftsession.com/drift_te...feintdrift.htm
crackerjack
Canadian Forum
Oct 27, 2015 05:35 PM
Cookboy
1st Gen General Discussion
18
Oct 12, 2015 06:55 AM
Vartok
Sep 24, 2015 02:20 PM
Kyo
11
Sep 16, 2015 01:59 AM
