Bridgeport vs. Streetport
Old May 30, 2003 | 11:34 PM
excitingleopard's Avatar
Prosthetic head.
What exactly is the difference in the different kind of porting to get?
First of all, I believe there are basically two kinds: bridgeporting and streetporting. Please correct me, because I'm probably wrong.
Other than the answer "bigger holes", what advantages are there for the "better" kinds of portings? (As in...how is Bridgeporting better than streetport... or is it?)
Any links would be helpful too.
Old May 30, 2003 | 11:52 PM
Conway's Avatar
Streetporting is any kind of porting which is limited to extending the stock ports. It allows somewhat better airflow, but the main source of power is the delayed closing of the intake port. This allows more air into the combustion chamber. This in turn creates more power. The downside compared to stock ports is that the power zone is shifted up higher. Therefor, the engine must be revved higher to achieve full power. Also, emmisions go out the window and fuel economy suffers.
Bridgeporting is similar to streetporting in that like streetporting, the intake ports are extended, but now a slit is cut next to the port which opens up the port sooner then before, while still allowing the corners seal to cross over a bridge of metal. (You have to see one to understand what I mean - try searchin) This shifts the power zone up even higher and substantially reduces low-rpm torque. Bridgeports get lousy gas mileage, have a rough idle and are really fast. J-ports and Monsterports are simply big bridgeports.
The other kind of porting is peripheral (sp) porting. The stock intake ports are filled and new ports are machined into the rotor housings, so they are on the periphery. Most power potential, but least drivability.
Hope this helps. Lots more info available in the archive or if you search.
Conway
Old May 31, 2003 | 12:56 AM
Prosthetic head.
Yes, that pretty much answers my question. And I will search in the archives as well.
Old May 31, 2003 | 01:10 AM
Here is pics of a street port and Bridge Port from Pineappleracing website
Old May 31, 2003 | 05:41 AM
Rotary7s's Avatar
Fat chicks hurt the 7
Dam thats a BIG bridge...
http://www.mazdarotary.net/porting.htm
Old Sep 16, 2011 | 10:54 PM
airman90's Avatar
nice info. just got a bridge ported rx7
Old Sep 17, 2011 | 08:18 PM
84stock's Avatar
Red Bull gives you wings.
Bridgeport gives you wood
Old Sep 18, 2011 | 08:35 AM
-xlr8planet-'s Avatar
I has an emblem
2003 thread .... nice
Old Sep 18, 2011 | 02:33 PM
wjk0817's Avatar
DD
Lol
James Knox
Oct 22, 2015 05:08 PM
LongDuck
Oct 7, 2015 08:12 PM
GKW
Sep 28, 2015 04:34 PM
