Ac
Old Sep 4, 2001 | 05:54 PM
MarkPerez's Avatar
Tennis, anyone
Ac
Has anyone recharged there AC lately ? did you do it yourself ?
and how many cans did it take ?after recharging,,did it blow cold
as before or not as cool. and is it a good idea to evacuate the system to (0) then fill with all the same refregerent,,,in other words,,,can the stuff be mixxed ?? does it matter ? thanks
Old Sep 4, 2001 | 08:22 PM
Pele's Avatar
Right near Malloy
Evacuate past 0.
It's a good idea to evacuate the system to -30 PSI, full vacuum if you can swing it. Then let it sit for half an hour to check for leaks. If the pressure goes up, theres a leak. The vacuum also helps it draw in the fresh refrigerant.
Put in as much refrigerant as you can, plus the reccomended ammount of A/C oil before you fire up the compressor.
Old Sep 4, 2001 | 09:14 PM
MarkPerez's Avatar
Tennis, anyone
OK,but i don't own such tools to do that though,,maybe it's better
to take it to a shop,and maybe with a coupon from our local penny-saver it won't break the bank,and if they screw it up,,,
i'll own them,i'de rather do it myself always,,,you know
Thanks
Old Sep 5, 2001 | 12:35 AM
Pittdp's Avatar
I had mine charged 2 years ago and they used 16 Ounces or one small can. It was not blowing out that cold of air before I had it charged, but runs strong now
Old Sep 5, 2001 | 08:45 AM
Pele's Avatar
Right near Malloy
Dude.
Thanks
Aww Man, You don't have any mechanic friends? You gotta have dudes you can goto for the expensive tools.
Any time I need expensive tools or ones that I don't own (Air tools, LARGE sockets, OBD computer, A/C machine, etc.) I goto the shop I used to work at.
Old Sep 5, 2001 | 03:19 PM
MarkPerez's Avatar
Tennis, anyone
Ok, so what kind of rig is used to get the system to -30lbs PSI ?
Old Sep 5, 2001 | 03:32 PM
Felix Wankel's Avatar
Super Newbie
A special vacuum pump. It's gonna take an HVAC tech to have the tools to do it properly (gauges and ****).
Old Sep 5, 2001 | 07:39 PM
MarkPerez's Avatar
Tennis, anyone
OK ,i know what i have to do,, thanks felix,,,guys
