DP Question
Old May 29, 2003 | 08:39 AM
DrunkenBowler's Avatar
DP Question
If you put on a dp, you eliminate the pre-cat. Will you sill pass emisions?
I don't want to put a dp on and then take it off just to pass emissions.
Old May 29, 2003 | 08:44 AM
JammerRX's Avatar
before everyone tells you too search...you're fine... it's when you remove the main cat that you start having emission issues
Old May 29, 2003 | 09:32 AM
Shinobi-X's Avatar
Sensory Experience
You need a well working air-pump, and main cat to pass emissions. If you are really worried about it, you can always buy products to put in your tank to help you pass, but you should be fine, assuming the other two I listed are in well working order.
Old May 29, 2003 | 10:02 AM
1st to 3rd's Avatar
I just passed with almost zero emissions and a downpipe. Just make sure the main converter is fully warmed up.
Old May 29, 2003 | 10:52 AM
Drifter93's Avatar
Are you using the stock cat or a high flow cat?
Old May 29, 2003 | 11:22 AM
adam c's Avatar
Cheap Bastard
You should be able to pass the "sniff" test with a downpipe. Be sure you go to a shop where the smog tech isn't too picky. Some states require that you pass a visual test, where the mechanic is supposed to check to see that all of the smog equipment is on the car, including the pre cat. Many mechanics don't check. Some do.
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
