O Rings and intake manifold
Old May 29, 2003 | 06:26 AM
TheMoonDog's Avatar
Question O Rings and intake manifold
Hi all,
I am starting to rebuild an engine I have here and when I removed the intake manifold there were no O rings on this manifold.
Is this normal?
I just went through installing an intake manifold on my 82 and had a bitch of a time with the O rings causing tears in my intake gasket because of the O rings. It seemed strange not to see any on this engine.
Old May 29, 2003 | 04:41 PM
Rx7carl's Avatar
Airflow is my life
No they are supposed to have orings.
Old May 29, 2003 | 04:54 PM
REVHED's Avatar
Hunting Skylines
Unless the coolant passages on the engine have been blocked off you will need the o-rings or it will **** coolant out.
Old May 29, 2003 | 09:49 PM
TheMoonDog's Avatar
That's what I always thought! May explain the green crud all over the engine huh?
I figured that whoever had the engine before must have been playing with it or had no idea at all. It is obvious that they ran it like this and I have no idea how it still has compression but it does. One would figure that it would have blown the engine.
Thanks for the replies, I thought I was missing something there!
Old May 29, 2003 | 10:32 PM
Suparslinc's Avatar
It's Back!
They could have disintegrated. I need to replace mine too, at the same time I plan to block off the ACV and shutter valve.
Old May 29, 2003 | 10:47 PM
1st to 3rd's Avatar
Ah, no.
The previous dipshit must have omitted them for some upgodly reason. O-rings causing tears in the intake gasket? You mean they slipping out of place during install? If so, then just put a dab of RVT on them to hold them in place while intalling. BTW, rubber and RVT shouldn't be used together as they have different coefficients of thermal expansion, so don't glob it on there.
Not exactly, unless it was overheating due to a lack of coolent. I bet internally your engine is clean enough to eat off of. Ever see a bonger after it blew a head gasket? Think of it as steam cleaning in insides of your engine.
Personally, I just block off the coolant lines to the intake. Cooler incomming air = more power. That and it makes future intake swaps a breeze.
Old May 29, 2003 | 10:52 PM
Rx7carl's Avatar
Airflow is my life
Use 20mm freeze plugs in the rotor housings. Oh and you owe me a 6pk now.
Old May 29, 2003 | 10:55 PM
Suparslinc's Avatar
It's Back!
Exaclty why do you want to block off the coolant lines to the intake?
Old May 29, 2003 | 11:12 PM
Rx7carl's Avatar
Airflow is my life
Less chance of a leak. Simplify,Simplify,Simplify,Simplify, Also it keeps the intake charge cooler.
Old May 29, 2003 | 11:14 PM
Suparslinc's Avatar
It's Back!
That part I get. I'm confused about the intake; would blocking off the passages make the car run hotter?
Old May 29, 2003 | 11:16 PM
Rx7carl's Avatar
Airflow is my life
No. That has nothing to do with the engine temps.
Old May 29, 2003 | 11:27 PM
rxtasy3's Avatar
If ur running an after market intake, the coolant doesn't run thru it anyway. So it makes it alot simpler when removing the intake at a later time without having to drain the coolant. I will be blocking mine off.
Old May 30, 2003 | 07:07 AM
TheMoonDog's Avatar
Hmmm, after all those posts it seems like maybe buddy was on to something. 20mm freeze plugs? I am fairly green when it somes to all this so what exactly are freeze plugs. another 6 pk coming up!
It sounds like not using orings may actually be possible if you put in the right stuff. If I am understanding all this correctly, it can actually help. Go figure! I'll tell you one thing for sure, it would be a hell of a lot easier to put the intake on!
Old May 30, 2003 | 12:22 PM
fatboy7's Avatar
Got Boost?
Hmmm, how do describe a feeze plug....... its basically a metal plug that you pound into the hole, its shape/pressure seals the hole, but if enough pressure on the inside is built up (ie, coolant freezing in the engine) it pops out, hopefully saving your block from cracking.
All engines have a few, ours are located in the rear housing, facing the flywheel and clutch.
Old May 30, 2003 | 12:23 PM
fatboy7's Avatar
Got Boost?
Basically 20mm freeze plugs are a good way to seal the coolant passages to the intake.
Old May 30, 2003 | 08:14 PM
nipper's Avatar
frost plugs is what we call them 'way up here in Canada.
Old May 31, 2003 | 12:38 PM
so if i buy me the rb intake i should block the coolant lines where the o-rings are?
Old May 31, 2003 | 08:21 PM
Pedestrian X's Avatar
SpAz!
yup, might aswell..
Old May 31, 2003 | 08:29 PM
hanman's Avatar
Moondog,
Not to be rude, but are you sure that you are up to rebuiilding a rotary engine? Are you doing it by yourself or do you have help?
Old May 31, 2003 | 11:24 PM
vipernicus42's Avatar
Rotoholic Moderookie
Hmmm... These o-rings are between the intake manifold and the engine block right?
Anyone know if there's supposed to be anything other than the plastic gasket between the intake manifold and the carb? I don't have anything other than the plastic there, and I've got a "mysterious" vacuum leak... I'm thinking of using something to gasketize between the manifold, the plastic, and the carb.
Jon
DerpyToast
14
Nov 23, 2024 05:19 PM
rgordon1979
40
Mar 15, 2022 12:04 PM
