Help - Power Mirrors don't work
Old Sep 4, 2001 | 04:20 PM
FlyGuy2000's Avatar
my 90 GTU doesn't have power windows or locks but has power mirrors? they don't work and i'm not sure which fuse is for the mirrors since the 30A slot is for the windows. can anyone tell me how i would go about fixing the mirrors? thanks!
Old Sep 5, 2001 | 02:55 AM
DJ!
take out the master switch and disconnect the plug from the back of the switch and find a battery feed and earth feed with a test light and see if you can power up the mirrors with the two feeds.If you can't power up the mirrors that could be your problem and you should check to see if you have any broken wires to the mirrors. if you can power up the mirrors you may have a faulty switch.
