rats nest removal question.
Old May 23, 2003 | 11:54 AM
Zoomspeed's Avatar
Finally down to the rats nest. Now exactly whch screws do I need to remove in order to take the rats nest out. Some pics would help too
Old May 23, 2003 | 12:06 PM
spurvo's Avatar
don't race, don't need to
When I was tearing down my engine, I found it easiest to remove the bolts that hold the entire tube rack. There's really only three of them, and they all lie under the coil pack. Working on pics here...
Old May 23, 2003 | 12:24 PM
Picture of rack screws
https://www.rx7club.com/forum/showth...hreadid=138077
look here (in the archives), at the bottom of the first page of posts there begins a series from me showing pictures of which of the screws you need to remove to get the solenoid rack out.
Old May 23, 2003 | 12:33 PM
spurvo's Avatar
here's the bolts I meant.
Why are you guys removing the pipe assembly? I did the whole job without dissasembly. Is this to clean the pipes?
Old May 23, 2003 | 01:32 PM
spurvo's Avatar
Post whoring as usual...
Here are some pics of the things I ran into with the hose replacement. Just some potential tips on routing and what not.
And no I didn't put tie wraps on EVERY connection. Vacuum hose connections suck themselve on tighter. Pressure connections were tie wrapped.
Old May 23, 2003 | 01:34 PM
spurvo's Avatar
and solution # 1
Old May 23, 2003 | 01:36 PM
spurvo's Avatar
and the other.
(/post *****, for now )
Old May 23, 2003 | 03:28 PM
xstacy7's Avatar
I love when things work
spurvo...your engine block is soo clean. I'm jealous now
Old May 23, 2003 | 03:44 PM
spurvo's Avatar
this one's fun!
SHOULD be clean after all that time and effort and mullah. Just wish it would hold water!!
Old May 25, 2003 | 06:03 PM
Zoomspeed's Avatar
Re: Picture of rack screws
Using this method, how would one even get to the screws onth e firewall side?
I took of the bolts in spurvos pic, then realized I'd ahve to disconnect the fuel lines to get it off that way. So, I got the srews out on the front side of the rats nest, but I dont' see how one is suppsoe to get the ones ont he firewall side off. There is no room to get a screw driver back there, unless I use stubby, 90 degree, or a bit on wratchet, all wiich will want to strip the screw.
Old May 25, 2003 | 07:20 PM
Zoomspeed's Avatar
HA! Finally got it out. Such a good feeling giving the rats nest the finger.
Old May 25, 2003 | 07:51 PM
kung stew's Avatar
face crunch
AMEN. I did that job last month...it sucked. I took out the whole rats nest. Use the 3M weatherstrip adhesive as mentioned elsewhere to secure the hoses. I thought it would cook w/ the heat and be useless, but did it anyway. After quite a few heat cycles, I checked some of the hoses and they are VERY hard to pull off. Just my 2 cents.
Stew
Old May 26, 2003 | 01:06 PM
JONSKI's Avatar
5yr member, joined 2001
Good job.
Old May 26, 2003 | 07:52 PM
mazda/feed's Avatar
hey dude before you do anything else dont touch any screws on the side of the rack all you will do is strip them, i was told by ray at PFS that i should just rovmove the fuel lines and it should just come out and damn if it didnt it if wasnt for hime i would be **** up the creek so hope this works
Old May 26, 2003 | 08:04 PM
vudoodoodoo's Avatar
If all else fails, cut that **** out w/ a dremel.
Old May 26, 2003 | 10:28 PM
Zoomspeed's Avatar
Thats what I was orginally going to do, I took out the bolts that hold them to the block, but then it was so hard removing the fuel lines. So I used soem PB blaster on the screws then used a power driver. Came out no problem
Old May 27, 2003 | 12:22 AM
apneablue's Avatar
Old May 27, 2003 | 07:44 AM
Originally posted by apneablue
Watch out for the fuel hard lines though.
Old Feb 28, 2004 | 07:59 AM
bladz311's Avatar
I cut that ****** out with shears, hehe
Old Feb 28, 2004 | 08:00 AM
bladz311's Avatar
damnit, just realized how old this thread is, hehe, woops.
