Massive Wheel Hop
Old May 21, 2003 | 06:40 PM
tomaszjc7's Avatar
Massive Wheel Hop
A few days ago I went to the track to see what my car could run in the quarter mile. I have always had the problem of wheel hop but it only occured once in a while. At the track every single time I launched the car I got sick wheel hop, so bad that I ran a 14.3, and as my best run I ran a 13.4. Anyway so before I would have splattered my diff all over the track I decided to go home. I read up on the forum about wheel hop and read that the rear suspension, toe link, trailing arms, and tires all have something to do with it.
I next went to M2's website and found this writtin under the trailing arms:
"NOTE: Flex in the rear suspension acts to store the torque applied to the wheels upon acceleration. This suspension flex is the main culprit in causing damaging wheel hop during drag-type launches. Use of the M2 Competition Trailing Arms and Toe Links has proven extremely successful in greatly reducing or eliminating wheel hop. This is as a result of replacing the OEM rubber bushings with the solid heim joints in the M2 arms. This allows for direct application of power from the differential to the wheels without the suspension alternately storing and discharging the force to wheels promoting wheel hop."
If i just got the trailing arms would that solve my problem? Has anyone ever had the problem and got M2 trailing arms, what was the outcome?
Thanks for any responces....
Old May 21, 2003 | 06:55 PM
MakoDHardie's Avatar
I installed a set of M2 trailing arms on another FD. They work pretty well with eliminating wheel hop. Installation is pretty easy as long as you get them adjusted to the right length before putting them in. If the wheels ever hop after that, its just a little bit, unlike the monstrous kangaroo bounces that occur on the stock bushings.
BTW, I recommend doing the toe links at the same time. Its not a very tough installation but it makes things easier to go ahead and get done while you're putting attention towards that part of the car.
Old May 21, 2003 | 06:59 PM
rx7racer11's Avatar
what tire pressure did you have??
Old May 21, 2003 | 07:49 PM
apexkw's Avatar
in slow, out fast!
chuck at rotaryextreme.com is making some custom toe end links and trailing arms. i just bought a set and should have them next week. i will let you know how they look when i get them.
Old May 21, 2003 | 08:37 PM
tomaszjc7's Avatar
i lowerd my tires pressure and it still hopped... about the rotaryextreme stuff, e-mail me at tomaszjc7@yahoo.com when u get em... thanks
Old May 21, 2003 | 09:38 PM
apexkw's Avatar
in slow, out fast!
hes got a pretty detailed thread about them on nopistons.com in the third gen section
Old May 21, 2003 | 10:58 PM
t-von's Avatar
Rotor Head Extreme
But the question is what tire pressure did you lower it too? When I go to the track I lower it between 14 & 20psi on stock tires. That in combination with a torque brace solves the wheel hop problem. I dont think those toe links are necessary!
Old May 21, 2003 | 11:04 PM
t-von's Avatar
Rotor Head Extreme
Old May 22, 2003 | 12:13 AM
Flyrx7's Avatar
Money Pit
Wheel size is going to play into this as well. 16's will hop less than 18's do to the tire sidewall flexing/absorbing properties too. I'm pretty sick of wheel hop myself, so it looks like I'll be doing the toe links and trailing arms soon too
Frank
Old May 22, 2003 | 01:07 AM
I reduced my wheel hop with a set of springs/shocks, rear sway bar and pettits toe adjustment linkage. Trailing arm linkage is my next mod to the rear end. hopefully i have fixed the dreaded wheel hop.
Old May 22, 2003 | 06:25 AM
the_saint's Avatar
Trailing arms alone cured by wheel hop problem 99%.
Even with racing beat lowering springs the car had huge hop problems.
Now I can lay a nice patch of rubber from a standstill no problem.
Spinning the tires once rolling, ie. 40+mph in 2nd ==> 60 mph has never been associated with wheel hop.
When I use my engine torque reaction strut (brace) there is zero wheel hop.
Toe links did not decrease wheel hop in my mind.
The diff bushings made a small improvement, but my stock diff bushings were in decent shape.
thesaint
Old May 22, 2003 | 07:00 AM
Scrapiron7's Avatar
STi Boxer power!
Check out the Rotary Extreme Trailing Arms and Toe Rods at this link. Chuck makes an excellent product.
http://www.rotaryextreme.com/rod.html
I ordered a set of the Performance Trailing Arms and am anxious to see how much they help.
Bryan
Old May 22, 2003 | 01:23 PM
tomaszjc7's Avatar
So pretty much the trailing arms and torque brace will solve the problem...
Old May 22, 2003 | 04:33 PM
DavidDeco's Avatar
I have more fun than you.
I have the trailing arms, ETB, Eibach Springs and Tokicos 5-way struts and have no wheel hop. Since they were all done except the ETB together, I can't tell you which one (if any single one) was responsible for the elimnation but ttogether they did it.
Old May 22, 2003 | 06:02 PM
Dan's Avatar
Dan
pettits street launch kit says it all.........
Old May 22, 2003 | 06:15 PM
red 7's Avatar
I have all the upgrades in the rear suspension--trailing arms, toe link arms, bushings in a-arms & diff, sway bar, coilovers, struts need PPF & torqe brace
the best thing ive done to reduce the wheel hop in my experience is to stiffen up the rebound/comp in the struts of course they have to be adjustable and dont lower too far, keep some suspension travel and of course lower tire press
when my struts were stock and i had lowered springs it felt like the stock struts wouldnt dampen the higher rate springs good enough and then the suspension would bottom out resulting in wheel hop and the toe links or trailing arm didnt help in my case my rear bumpstops were almost gone from bottoming out
Old May 22, 2003 | 06:28 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
be carefully... a hop can lead to a roll
h r p
Old Jun 2, 2003 | 06:12 PM
rxrotary2_7's Avatar
are any of you interested in a brace for your diff? https://www.rx7club.com/forum/showth...hreadid=191383
Old Jun 2, 2003 | 06:38 PM
vosko's Avatar
Just Call Me Terminator!
hmm lets see i have
pettit launch kit, trailing arms and toe links
solid tranny brace *similar to a FC tranny mount*
300M axles
TII clutch LSD
two parts waiting to be installed are a diff brace and subframe braces.
i haven't broken anything in a while and my wheel hop is basically gone. the pettit launch kit helped a little. installing better diff bushings will also help alot. i am still running the stock bushings for now
Old Jun 2, 2003 | 08:39 PM
fastrx7man's Avatar
Looking for 10's
I too had bad wheel hop...I put on a set of ET streets and the car has not wheel hopped once. I launch the car between 5500 and 6000 RPMs. All the car does is squat and go. My worst 60' since I installed them has been a 1.94. So my suggestion would be get a set of ET streets on your stock wheels and see if that solves the problem
Good Luck....
Old Jun 2, 2003 | 08:45 PM
Resource's Avatar
Why not just throw in a 8.8
Old Jun 2, 2003 | 08:48 PM
teamstealth's Avatar
Ozone Depleter
i heard somewhere that different trailing arms can affect handling???? anyone else heard this cuz it sounded pretty bizzare to me
Old Jun 2, 2003 | 08:55 PM
Resource's Avatar
We still have a few sets of upgraded trailing arms for sale. Let me know if you want a set.
Old Jun 2, 2003 | 08:56 PM
Can the stock rear end take some really stickey tires...ie et streets...
