Power FC Vaccuum?
Old May 19, 2003 | 03:37 PM
CYM GIRL's Avatar
Vaccuum?
Can someone explain to me how to look up the vaccuum on the commander and what the hell is vaccumm?
Also, how would I know the compression on my FD?
Old May 19, 2003 | 04:21 PM
skotx's Avatar
Registered Abuser
You'll see vacuum when you're monitoring boost. Numbers greater than zero will be represented in kg/cm^2, such as 0.70. Numbers less than zero (vacuum) will be represented in mmHg. -450 mmHg of vacuum is about what you want to see on the commander when idling.
To convert these number from metric to imperial, go here.
Compression tests require a special tool and are best left to a qualified shop.
-Scott
ponykiller
Apr 10, 2003 08:59 AM
ponykiller
Mar 22, 2003 07:08 PM
Project84
Sep 8, 2002 06:39 PM
93R1
Apr 25, 2002 10:41 AM
93R1
Apr 24, 2002 10:46 PM
