siren sounding sound and low secondary boost
Old May 18, 2003 | 06:29 PM
ttb's Avatar
ttb
No Cup Holder Racing
i'm getting low boost (3-4 psi) when the seconadaries are suppose to kick it. it's accompanied by a police siren sounding sound. i'm thinking somebody most have heard this sound before and can quickly tell me what the problem is.
the car was running fine this morning. on my way to the bay area's rx-7 dyno day i decided to turn up the boost on the PFC. just so happen to see a a new 911 turbo and wanted to see how bad i would get left behind. think the PFC wasn't that good at controlling boost, went up to 14psi instead of my desired 12psi. after that the car started make the siren sounding sound whenever i'm trying to give it throttle and let go quickly at higher rpms.
thanks
Old May 18, 2003 | 09:47 PM
KibagamiR2's Avatar
From: So farrrr away from the Land of the Rising Sun
Re: siren sounding sound and low secondary boost
thanks
How many miles are on your turbos?
I have hearda turbo car make a similarly described sound when a compressor turbine is rubbing the housing. in other words *turbo rebuild/replace*
-Kib
Old May 18, 2003 | 09:59 PM
Johnny's Avatar
OG
Re: Re: siren sounding sound and low secondary boost
-Kib
heard the same on my primaries...
yep time for new turbos
Old May 18, 2003 | 10:19 PM
Brentis's Avatar
In the supra world it is called the "death whine"...
Old May 18, 2003 | 10:51 PM
ttb's Avatar
ttb
d'oh!!!!
turbos have 107k miles on them. damn, i was hoping it would be something stupid like a hose or solenoid, but new turbos...damn, the 911 turbo literally fucked me up!!!!
Old May 19, 2003 | 08:29 AM
KibagamiR2's Avatar
thanks
-Kib
Old May 19, 2003 | 12:15 PM
ttb's Avatar
ttb
computer glitch? or are you experiencing some time warp :p
Old May 19, 2003 | 04:25 PM
rx7speed811's Avatar
Accepting Donations.
hes caught in the matrix.
Old May 19, 2003 | 04:46 PM
j9fd3s's Avatar
Community Builder
it could be the one remaining rubber boost hose too, check it yo
mike
Old May 19, 2003 | 04:48 PM
ttb's Avatar
ttb
you turning ebonics on me mike?
Old May 19, 2003 | 04:49 PM
j9fd3s's Avatar
Community Builder
i thought it was an east bay thing?
mike
Old May 19, 2003 | 08:49 PM
r0gu3's Avatar
Boostless FD
I had a similar problem and it turned out to be a broken check valve.
Old May 19, 2003 | 09:24 PM
im telling you tinou, check the turbo control actuator, the physical actuator with the sliding vacuum activated rod and butterfly type door, not just the solenoids and check valves. i would really recommend starting with that.
Old May 20, 2003 | 01:43 AM
KibagamiR2's Avatar
Stupid server timed out...
hence the duplicate and late post
-Kib
Old May 26, 2003 | 12:08 AM
ttb's Avatar
ttb
if anybody cares....it turned out to be a faulty solenoid.
Old May 26, 2003 | 12:44 AM
memmi's Avatar
I care! thanks!
Old May 26, 2003 | 03:39 AM
r0gu3's Avatar
Boostless FD
Glad you posted the outcome and fix.
Old May 27, 2003 | 05:42 AM
SleepR1's Avatar
ttb, were the solenoids, the turbo control solenoids, just underneath the extension manifold (UIM)? How how hard were those solenoids to replace? I'm having some issues with my secondary turbo control, like you did. I'm hearing a whistling sound between 3000 and 4500 rpm, right when the secondary turbo is supposed to be spooling.
There are two solenoids that control the turbo control actuator--one solenoid applies pressure, the other applies vacuum. Both are needed for the turbo control actuator to work properly.
My J-spec twins are 5200-miles new, so I can't believe my turbo control actuator is bad. I did replace the 1-way vacuum chamber check valve to no avail. A disconnected vacuum line beween the turbo control actuator and the vacuum line tray might also affect the function.
Did you try getting out of the gas, and then reapplying the gas to get the secondary turbo online? This is the classic symptom of a vacuum leak or turbo control solenoid/actuator problem?
Getting off and then back on the gas is what I must do to get the 2nd turbo to come online...a PITA, when trying to race a 911 twin turbo, you know LOL
I plan on replacing the turbo control soleniods, a couple of more check valves (vacuum line, double throttle control, and pressure chamber), and checking the vacuum line between turbo control actuator and rat's nest this week.
Hopefully I'll be back on the road killing 911 twin turbos like you are
Old May 27, 2003 | 12:33 PM
ttb's Avatar
ttb
wished i could be more helpful, but i'm one of those guys that don't work on their cars :-(
forgot all the details my mechanic told me...from what i remember it was because my solenoid was faulty. he said something like he measured the resistance/voltage and it was too high (?), and the ECU didn't pick it up because I have a power FC. so he replaced it with a used solenoid. and now i'm boosting fine again.
and yea, my problem was kinda on and off..sometimes i was able to get it to boost fine, other times it wouldn't.
i'll probably see him within the week to pay him, so I'll ask him exactly which solenoid was bad and let you know.
tinou
Queppa
Nov 18, 2024 03:47 AM
cristoDathird
28
May 30, 2019 08:47 PM
20B Forum
Aug 30, 2015 12:08 AM
old_skool
Aug 25, 2015 08:06 PM
