what do it do?
Old May 16, 2003 | 02:12 PM
my93rx7tt's Avatar
what do it do?
there is a whole bunch of antifreeze in the oil, when i take the oil cap off its all foamy and u can see the bubbels of antifreeze in there, i assume the seals r shot, kind of like a head gasket, time for a new motor?
Old May 16, 2003 | 02:15 PM
Street King's Avatar
*** Bless Texas!
new motor time
Old May 16, 2003 | 02:16 PM
Marshall's Avatar
How does antifreeze get into the oil on a rotary?
Old May 16, 2003 | 02:18 PM
jpandes's Avatar
Well, I haven't seen coolant bubbles in my oil before, but does your car spew white smoke at start-up? Especially, if the car has been sitting for a couple days? If it does. that mean your coolant seals are gond and you need to get e rebuild.
Old May 16, 2003 | 03:21 PM
my93rx7tt's Avatar
yeah it smokes like a **** untill it is warmed up i mean like bad where i cant see anything, lots of smoke on start up, once its warmed up it goes away and it is fine.
Old May 16, 2003 | 06:56 PM
Flyrx7's Avatar
Money Pit
A bad outer O-ring at the bottom of the engine, between the engine and pan would do it.
Old May 16, 2003 | 06:59 PM
Flyrx7's Avatar
Money Pit
You need to do a leak down/pressure test on the coolant system. Also, is the dipstick in your coolant resevoir tank blackish? Does the exhaust smell sweet when it's smoking? How many miles since rebuild/new?
Frank
Old May 16, 2003 | 07:02 PM
Flyrx7's Avatar
Money Pit
Also, is it hard to start sometimes? And when it does start, is it very rough and lumpy, with huge clouds of smoke? If so, it's money time (rebuild).
Frank
