anything else i need to order?
Old May 12, 2003 | 12:34 PM
rx_7_driver's Avatar
i did a aliment on my car the other day and adjusted the toe on all 4 tires, the camber in the rear is way of at -2.2 (left side) and -2.5 (right side). i am ordering the Rear Camber Adjuster from mazdatrix.com (the one u can adjust it with it on the car) do i need to get anything else? will it bolt right up? and anyone know how difficult it is to install it?
thanks
-Shawn
Old May 12, 2003 | 01:16 PM
SureShot's Avatar
Seduced by the DARK SIDE
Let me guess - unlisted mod 1.5" drop.
It looks like you got the right stuff.
The guys at Mazdatrix know what's needed.
Old May 12, 2003 | 01:26 PM
nope, no 1.5" drop (dosen't anyone else think our cars are low enough as it is??), i think its the 17' rims that i am stuck with.....
-Shawn
Old May 12, 2003 | 01:47 PM
SureShot's Avatar
-Shawn
It sounds like you're stuck with a pretty good ride.
By the way what tire pressure are you running?
I find that running 26PSI in low profile negative cambered tires gives a full footprint and really improves handling.
Old May 12, 2003 | 02:28 PM
JerryLH3's Avatar
Rabbit hole specialist
If you want some really neat pieces and want to independently adjust the camber of each wheel, buy these
It can be found here
http://www.mazdatrix.com/h6_86-92.htm
Otherwise, the camber of both your rear wheels will always be different
Old May 13, 2003 | 03:55 AM
just wondering.................. this peice that i am going to be replacing, does it wear out r something(referring to the oem peice)??? i mean even the spare tire wore out the same way as the 17"rims.......... i already replace the springs and shocks in the rear and it still does this
-Shawn
Old May 13, 2003 | 08:02 AM
SureShot's Avatar
Old May 13, 2003 | 08:33 AM
Relisys190's Avatar
REINCARNATED
surshot what tires size do you run? Do you still have the stock 15" rims? I am running stock GXL 15"x6" rims.. I also have 225-50-15 on all four corners. I run at 30 PSI now, should i bump it down a little?
-Markus
Old May 22, 2003 | 04:36 AM
36psi anylower and the car does not respond well to sharp turns
-Shawn
Old May 22, 2003 | 06:13 AM
The Only SlidinRX7
Our cars are actually low for a stock car, but I don't think it's low enough. LOL I want to get coilovers from Tein or JIC so I can drop my car even more than what it is now and it's pretty low now. Tires tucked in the front.
-Markus
I would suggest getting 205/60/15, 205/55/15, or even 205/50/15 on all four corners. Sure the 225's leaves a bigger footprint, but since the tire bulges out, it rolls over more. With a 205/60/15, the tire doesn't bulge as much, so it'll respond better. On the other hand, if you drag race, then the 225's would prove to be useful. Drag racing only requires traction to go forward and no side G's, which is why the sidewalls of drag slicks aren't stiff.
Old May 22, 2003 | 12:38 PM
SureShot's Avatar
-Markus
Sorry I missed you question last week.
You should be good at 30-32.
My lowered pressure is strictly to compenaste for my 1" drop & the extra spring stiffness.
I do run 2PSI more in the front than the back.
NickNac113
13
Oct 1, 2015 09:25 PM
