rear end clunking (not the normal susp clunk)
Old May 10, 2003 | 12:46 AM
particleeffect's Avatar
omgwtfposlol
I know I need to replace my clunking bushings, but this sound is more of a constant "thud.thud.thud.thud...". It comes and goes but anytime it does come a small upset in the momentum of the car from the gas or brake peddle will stop it. It only comes on (or I only hear it) when im crusing at under 40. It's wierd, It's very hard to replicate on purpose. I don't remember feeling anything when it happens, but it's happend maybe a dozen times now, most normally when I'm idling down my road at under 20...
Anyone know what this might be?
Old May 10, 2003 | 12:31 PM
djantlive's Avatar
check around loose suspension pieces. Also, is there enough differential oil? Are the rear axles in good shape? Spray some WD 40 around the wheel / suspension joints to see if anything helps. Lastly, is this just a sound or also some bouncing? If bouncing, maybe it's wheel balance, not likely but worth a shot.
Old May 10, 2003 | 01:00 PM
Street King's Avatar
*** Bless Texas!
Watch the WD-40, it's a solvent.
Old May 11, 2003 | 12:32 AM
omgwtfposlol
I haven't found any loose peices, but I have no idea what my diff fluid level is at. As for the axles, they are there, heh, I could look more carefully tomorrow. It's just a sound, I don't really feel anything.
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
