Map Sensor.....
Old Aug 31, 2001 | 01:53 AM
RotaryMan's Avatar
Lightbulb Map Sensor.....
Hey guys gotta question.....u know that hose that connects between your MAP sensor and the manifold.....well that small filter that is inline between the MAP sensor and manifold is it a filter that can flow in both directions or is it a one way check valve.......? I inspected mine and it was flowing in both directions....but when I shook it around a little I could hear something rattling around inside....so I figured it was a one way check valve that went bad....so I replaced it with an after market 1 way check valve. and installed it so that air would be flowing away from the sensor(so it would read vacuum)... Car seems to run ok with it. dunno..... So maybe u guys might..... Thanx.... Tony
Old Aug 31, 2001 | 02:08 AM
spooledUP7's Avatar
There and back again
Nope, it's just a filter. The arrow is so that the dirty side of the filter is always the dirty side. I can't imagen that a check valve would allow the car to run well. How would boost, or Vacuum be read at the same sensor. Strange
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
nismorx7
Power FC Forum
Oct 1, 2015 10:36 AM
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
