Location of rear license light fuse and rear running light fuse
I know that it seems odd and a bit dangerous, but I'm looking to cut the line to my rear running lights (I think that's what the red ones are called) and the rear license lights (I know that's right).
I already did the brake lights by cutting the line at the little switch right above the pedal. Then I ran a line to a toggle switch, then to a little blue light, then back to the original line. It works quite well. I can now turn off my brake lights at will
Like I said, I know it's dangerous. It's more of a novelty than anything else.
Anyway, I am now looking to do the same to the other rear lights but I don't know where to find the line to them or where I should cut it. Any help is appreciated.
BTW, there's four toggles with blue lights below them mounted in aluminum right above my stereo (also in the aluminum). Looks SWEET.
Thanks
Thanks
