Microtech The Unified LT Impression Thread
Old May 5, 2003 | 11:54 PM
No7Yet's Avatar
Speak up, guys. Now that you've installed and begun to tune your Microtech-equipped cars, let's get a repository of impressions and opinions going.
What things about the MT stick out as being the best?
What's the worst?
What problems have you had, and was the solution easily found and implemented?
If you have experience with both the LT8 and the E6K, how do the two compare? What does one have over the other?
If you had it to do over again... would you still get a Microtech?
Brandon
BR7 Racing
Old May 6, 2003 | 08:07 AM
SaabGuy's Avatar
I think the ecu is great!!! Now that I've had some time to figure things out, I am able to reasearch what the engine probably needs and apply that information to the maps. i must run out to my car twice a day to pick at some of the correctional maps such as water temp, crank, and air temp.
The only thing I think it is lacking is outside variables such as ambient air temp, barometric pressure, humidity and the like. Other than that the units is kick ***!!
Im still trying to figure out how to get my A/C to work (properly) and I cant get my BAC to work from the ecu's output. This is pretty minor stuff though.
Old May 6, 2003 | 11:32 AM
RotaryRevn's Avatar
I thought the BAC wasn't needed with a microtech?
Old May 6, 2003 | 11:57 AM
SaabGuy's Avatar
It is not. Right now it isnt even hooked up. Im thinking of just ripping it out pretty soon anyways.
Old May 6, 2003 | 12:22 PM
600HP CLUB's Avatar
my BAC is just sitting there becuase i have no block off plate and i still have the coolant routed into it, front water pump->bac->rear rotar..
soo yeah it isn't needed, i got my car running with the hard idle screw (13bt) the hard idle screw behind the throttle body.
RX7-RR
Jun 10, 2018 11:40 AM
risingsunroof82
22
Sep 22, 2015 01:20 PM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
