Removing extra pullies.
Old Apr 26, 2003 | 08:35 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
Ok I now have one belt on my engine: no a/c, air pump, or PS. I searched a bit and found this thread:
https://www.rx7club.com/forum/showth...main+and+pully
I have an S4 engine I want to remove the parts of the main pully that used to be for the AC and PS do I just remove the four bolts or do i have to take off the large one too? Do i still have to derpress the clutch while I do it? Do I need to know anything else befor I do this?
Old Apr 26, 2003 | 08:48 PM
dr0x's Avatar
pei > caek
4 10mm bolts. And no you dont have to depress the clutch. Just make sure you leave the 19mm nut in the middle alone.
Old Apr 26, 2003 | 08:50 PM
1987RX7guy's Avatar
do i have to put the four bolts back in afterwards? or do they stay out?
Old Apr 26, 2003 | 08:56 PM
BlackRx7's Avatar
Daily Domestic Killer
yep those hole the pully on the hub itself, it may be a pain to get those other pullies of just take your time
dr0x's Avatar
pei > caek
You need to keep the one closest to the engine. But the others can be taken off. I think its a 3 piece set?
Old Apr 26, 2003 | 08:59 PM
1987RX7guy's Avatar
drox-ok which one is the closest to the engine.
blackrx7-I did not quit understand what you said.
Old Apr 26, 2003 | 09:24 PM
BlackRx7's Avatar
he sorry I'm feelen sick, messen up my typing, those 4 bolts hold all the pully's on a single hub that the 19mm bolt secures to the engine, by removing the 4 bolts you can remove the air pump, and P/S pully, but it would be a good Idea to keep the 2 pully's are the same size, here a pic is worth a 1000 words
Old Apr 26, 2003 | 09:59 PM
1987RX7guy's Avatar
yeah
ofcouse I am keeping the one for the water pump/alt I only need to take off the a/c and ps pullies. thanks guys
Old Apr 26, 2003 | 10:12 PM
pengarufoo's Avatar
The mystery of the prize.
you can remove those 4 studs on your water pump pulley just as easily also. Would hate to see one of those loose wires get caught in them with the engine running... or worse yet, the sleeve of your shirt.
Old Apr 26, 2003 | 10:18 PM
BlackRx7's Avatar
hehe very true, I'll do that one of these days, btw 1987rx7guy I Have a dual belt pully, I know the pic looks like I'm only running one belt but there is actually two, so just make sure to keep the to pullies that are the same size, I think there connected so it should be a problem, decided its time to chnage the avatar and sig
Old Apr 26, 2003 | 10:23 PM
1987RX7guy's Avatar
yeah I need to get the dual pully now cuz i think it is starting to slip i guess since i only have one belt it is taking all the tourqe from the engine as opposed to it and the PS belt.
Old Apr 26, 2003 | 11:03 PM
BlackRx7's Avatar
well you don't even need a dual alt pully check this out
http://www.1300cc.com/howto/how2/belt.htm
Old Apr 27, 2003 | 12:41 AM
1987RX7guy's Avatar
yeah I know about that but I like the idea of having a back-up belt for te alternator just incase.
Old Apr 27, 2003 | 01:29 AM
deltr0n`'s Avatar
Track Junkie
wait a minute, to take off the crank main e shaft pulley, all you need to do is undo the 4 small ones? i thought you had to take out the big center nut as well...
can someone clear this up for me?
Old Apr 27, 2003 | 01:44 AM
Jimmy325i's Avatar
No longer cares
The TII in the pic in this thread has an extra piece on it as well. That spacer ring isn't needed either. The hub is thick enough to prevent any thread contact from the bolts and one pulley.
The 4 outer bolts are the only ones which need to come out. If you pull the center bolt you will remove the hub. (not needed and can be very bad for your engine if done wrong)
The center of the pulleys is pretty tight tolerance to the hub, so rust builds up in there and locks them together. Some persuasion with a deadblow hammer or rubber mallet should liberate the unwanted pulleys. Just make sure you line up the holes in the hub with the pulley right. It is timed with the crank afterall and the timing marks need to be in the right spot. (there's only one way to install it, so don't go hogging out the holes to make it fit)
Old Apr 27, 2003 | 01:48 AM
deltr0n`'s Avatar
Track Junkie
really? thats wierd... i thought you had to take out the huge middle nut to take off the main pulley, thats definitely a plus, i can install my SR underdrive main pulley now...
Old Apr 27, 2003 | 01:57 AM
Jimmy325i's Avatar
No longer cares
Yep, I just did it again yesturday after having to pull the pulley off to remove the water pump housing. (now I have a mechanical water temp gauge)
I want to replace my steel pipe thermowax pellet fix with a better one and I am afraid of messing up my backlash on the e-shaft if I take it back out.
Old Apr 27, 2003 | 02:09 AM
deltr0n`'s Avatar
Track Junkie
yeah i want to do that too, but same thing...you gotta be very careful with that ****...sweet, im gonna install my pulley tomorrow morning...or should i do it now? hmmmm....
Old Apr 27, 2003 | 02:42 AM
deltr0n`'s Avatar
Track Junkie
LIAR!!!! **** mannn i did all that for nothing....you HAVE to take out the main bolt to get that center piece out of there...
Old Apr 27, 2003 | 02:53 AM
Jimmy325i's Avatar
No longer cares
You don't need the "center"piece out to remove the pulleys though. The only thing you need is the four outter bolts removed and the hub stays put. It might not want to let go of the pullies due to them being rusted in place.
Or, your underdrive pulley replaces the hub... in which case you have to only remove the center bolt and then take the hub out and replace the whole thing.
Do you have a pic of the underdrive pulley?
Old Apr 27, 2003 | 03:10 AM
j200pruf's Avatar
RIP Icemark
Jimmy is right dude, the pulleys are secured to the hub via the 4 bolts, only the hub is secured by the fron e-shaft bolt. (If you want proff I can post a pic of my newly rebuilt motor
Damn Jimmy everyone has to call you a liar don't they
Old Apr 27, 2003 | 03:18 AM
Jimmy325i's Avatar
No longer cares
Well, I hope to get my front sticky 6 port sleeve working or I might have to dyno sunday with them wired open. It sucks because I have two massive papers due this week and no time to work on the car. My front right wheel bearing is possibly making noise. (I have play but cant tell if its the ball joint or the bearing yet) Too much **** to do!
My airflow readings are down 5% from where they should be, and my car is acting hella rich now that I disconnected my a/f meter. It's all really bad timing, considering the dyno session will only allow two pulls this time around. (group event thing)
Still doesn't change the fact that I could hang with a mustang GT up into 3rd with him in front of me controling the launch tonight. I don't give a rats *** who believes me.
I will be putting up the proof soon enough though. Call me whatever you want, but you better be damn sure you can back it up.
Old Apr 27, 2003 | 03:29 AM
j200pruf's Avatar
RIP Icemark
Good deal.
Sry for hijacking your thread there Guy
Old Apr 27, 2003 | 05:05 AM
deltr0n`'s Avatar
Track Junkie
heh sorry, i got it... see the pulley i have came with a hub...so after a bit of pounding i got that one out and slid the pulley onto the original hub on my car already... i thought it was all one piece, but it turns out its not... thanks for the help dude!
i took it for a spin real quick after i finished and didnt notice any difference... do these add to the top end or what?
oh and one more question... how tight should the belts be? you cant OVER tighten them can you?
Old Apr 27, 2003 | 01:28 PM
Jimmy325i's Avatar
No longer cares
Yes, you can over tighten them. The answer is tight enough that they don't slip, but thats not very helpful. You should have enough slack to move the longest stretch of belt no more than 1/2".
If you tighten them too much you put excess side load on the bearings in the alternator and water pump and will end up with those components failing early.
