Sponsored by: CARiD
turbo timer installation problems..
Old Apr 24, 2003 | 09:28 PM
Recipe7's Avatar
With Life.
i resently bought a turbo timer of which i dont know jack diddly about how to install it into my car. can anyone actually give me some help or a general place to have someone put it in for me. thanks alot
PS: i looked, but found nothing. i also read that manual that came with it, and i have no idea what wires they are talking about. also im 16 and im stupid
Old Apr 24, 2003 | 09:36 PM
apexkw's Avatar
in slow, out fast!
um what company is the turbo timer from....greddy, hks, apexi,???? anyways did it come with a harness? if so it should be pretty esay. give us some more info. also you should try to post this in the 3rd gen forum. more traffic there.
Old Apr 24, 2003 | 10:59 PM
Recipe7's Avatar
With Life.
it is a greddy, and it did come with a harness. is there anything else i should mention? if i dont get much luck here i'll post in the 3rd gen =p
Old Apr 25, 2003 | 12:19 PM
apexkw's Avatar
in slow, out fast!
then you should look under the steering column and there will be a spot that has a white connector. unplug it and put the turbo time harness there. then you run the loose wire to the ebrake handle. and then ground out the other wire. the purple wire is for the speed sensor but you dont need to hook it up. overall it should take you about 20mins TOPS!!! to do this.
Old Apr 25, 2003 | 12:29 PM
Recipe7's Avatar
With Life.
i understand where to put them, but im having a hard time locating these spots. i can find the wires under the steering column, but i cant find anything on the ebrake. i just took off the plastic around it and didnt find much, and i was afraid to break it. should i dig in more into the ebrake, and is it on the side of it? or where?
Old Apr 30, 2003 | 01:19 PM
apexkw's Avatar
in slow, out fast!
you need to hook it up to the sensor wire on the ebrake. dig around a little more.
Old Apr 30, 2003 | 07:52 PM
jgrts20's Avatar
Who are you?
nice pix apexkw, babelicious!!
Th0m4s
Feb 26, 2019 02:04 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
