rear end bolt pattern question
Old Apr 23, 2003 | 06:09 PM
eddierotary's Avatar
back with rotaries
im searching latelly about the ford 9" and chevy 12 bolts rearends and i would like to know if ethier of one have the same bolt pattern of a turbo II that is 114.3x5 or wich rear end i can use that have the pattern? thanks
Old Apr 23, 2003 | 06:25 PM
rotor vs. piston's Avatar
Function > Form
You can get the axels drilled for your own bolt pattern.
Old Apr 24, 2003 | 12:16 AM
fatboy7's Avatar
Got Boost?
On either the Ford 9" or the Chevy 12-bolt you'll have to have them shortened, and the axles custom made, so you you can have them made any way you want.
Old Apr 24, 2003 | 06:53 PM
back with rotaries
but any of them comes with that pattern from the factory? thanks
Old Apr 24, 2003 | 07:04 PM
Function > Form
No, I'm 99.9% sure of it.
Old Apr 24, 2003 | 10:49 PM
back with rotaries
well ok. im planning to make a turbo II front brakes swap but i dont know about the rear end ill probably get a 9" and amke the patter. thanks
mazdaverx713b
48
Apr 21, 2016 06:45 AM
