Stock injector connectors?
Thanks for taking the time to reply, duboisr! I was however checking to see if anyone had a more "economical" answer... being the cheap bastard that I am!
Hey Kent,
Sounds like a good lead. Did you literally just ask for GSL-SE injector connector, or was there a part number or other associate specifcation?
The autozone guy pointed one out in the electrical supply section. It is the section were they have factory connectors, switches, etc. The one style of injector connector that they sell is black, boxed shaped, and has two white wires running from it. This will work for your seven. They are Bosch style connectors. I also believe they work for GM cars.
Good Luck.
Kent
Good Luck.
Kent
Trending Topics
Megasquirt timing map and EGt ?? what do you guys think
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
armans
Aug 15, 2015 09:08 PM
