Knight Sports EBS III Questions
Old Apr 11, 2003 | 12:40 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
Any of you guys running a Knight Sports EBSIII and can help me with a question or two? I am just wondering what the switches on the side of the brain box do? There are 2 switches and a dial. The switches are W or N and P or S. The dial goes from W to N also. There is also one wire that comes off the harness that I cant think where would go. Any help would be most apreciated.
Thanx in advance
Jeremy
Old Apr 11, 2003 | 01:47 PM
Broken09's Avatar
I am becoming...
this is just a guess on my part, but I'd think the W and N dial is for throttle position. As in where the fuel correction comes in at. W being Wide and N being Narrow. as for the P and S I don't know sorry if that's no help just my 2 cents
Old Apr 11, 2003 | 07:01 PM
As you look at it from above switches they are as follows/right switch is wastegate switch,left switch is overboost alarm switch and the volume type dial to bring boost in at various speed.Set the right switch(waste gate)to the right -set the left switch(alarm switch)to the left so alarm sounds if you go above your set boost and set the vol dial at 12 oclock and adjust from there.If you turn it left boost responce is faster and if you turn it right boost will pick up steadier and you will have more control over it.Roy UK. Mail me if you need any help at royston.pugh1@btopenworld.com
Old Apr 11, 2003 | 11:43 PM
PureMdMa's Avatar
Cool thanx alot, oh yeah and there is a wire hanging from the harness that is green with a bullet plug on it, I cant seem to figure what it goes to. do you know what this is for?
Old Jun 21, 2011 | 04:14 AM
B-TAG's Avatar
the green wire should be a constant
_Tones_
May 25, 2021 05:37 AM
