quick vacum hose sizing question
Old Apr 7, 2003 | 06:00 PM
psi4psi's Avatar
Question quick vacum hose sizing question
what size are the 4 hoses that go from the intake manifold to the Y-pipe? 3.5 or 6 mm? mine are hard to measure. thanks
Old Apr 7, 2003 | 10:33 PM
ROTORHP's Avatar
i love boost
If you are refering to the 4 pipes that go to through the LIM, they are 3.5 mm. 4mm lines fit just fine, if they're silicone.
Old Apr 7, 2003 | 10:38 PM
ROTORHP's Avatar
i love boost
DOH....double post
Old Apr 7, 2003 | 11:54 PM
psi4psi's Avatar
thanks
Old Apr 8, 2003 | 12:47 AM
ROTORHP's Avatar
i love boost
Your welcome......
Old Apr 8, 2003 | 09:31 PM
psi4psi's Avatar
do you know what size the CRV and BOV hose is?
Old Apr 9, 2003 | 08:14 PM
ROTORHP's Avatar
i love boost
3/4" I.D ..... I busted the CRV hose when I took mine off. I got Goodyear hose to replace it.... it is blue hose and it is supposed to be higher heat tolerant. If it buckles when you install it, just stick a spring in the hose at the bend. The stock hoses are molded....
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
