How much hp can an HKS Twin Power support?
Old Apr 4, 2003 | 03:03 PM
Pressurized's Avatar
the thought just crossed my mind while looking at other members setups. my goal is to make 650+whp and the sky's the limit, i might even be using propane or methanol injection...i am planning on using the Twin Power, but will it be able to provide enough spark....or should i upgrade?
Old Apr 4, 2003 | 03:19 PM
mjw's Avatar
mjw
You need a REAL ignition setup for something like that, forget about the twin power. You will need MSD ignition boxes and blaster coils, forget about the stock coil setup. I'd consider the twin power a mild upgrade that works well with stock twins/smaller single turbos.
Old Apr 4, 2003 | 05:47 PM
Well there are a few 7's here in Columbus that are making 500+ with the TwinPower...so...i was just curious.
streetlegal?
Mar 17, 2022 02:46 PM
