where is the power mirror wire??
Old Apr 4, 2003 | 01:02 PM
rybrx7's Avatar
Exclamation where is the power mirror wire??
i want to remove my passenger side power mirror but i dont know where about behind the passenger door panel it is. i have removed all the screws but the centre part of the door panel by the window wont come loose for some reason, i have removed the 3 outer screws and the one by the lock in the insert.
so rather than break it i will just pull it out and grab the wire, but where about is it???
cheers
Old Apr 4, 2003 | 01:53 PM
Mahjik's Avatar
Mr. Links
Here's how to remove the entire panel:
https://www.rx7club.com/forum/showth...hreadid=165527
As for just the power window switch, just carefully pop it out with a screwdriver.
Old Apr 4, 2003 | 02:15 PM
rybrx7's Avatar
yeah cheers i meant the passenger side, i disconnected the cable it was behind the speaker holder.
but i can get the door panel off still, i lifted if up and it sort of gets stuck in the centre at the top...... sort of around the handle area.... do i definitely have to disconnect the windows button?
Old Apr 4, 2003 | 02:35 PM
Mahjik's Avatar
Mr. Links
Read the link, it tells you how to remove the panel.
streetlegal?
Mar 17, 2022 02:46 PM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
