2g fuel pick up and pump question
Old Apr 1, 2003 | 03:42 PM
eddierotary's Avatar
back with rotaries
does somebody have try to put a 2g fuel pick up and fuel pump in a 1g gas tank? thanks
Old Apr 1, 2003 | 06:46 PM
back with rotaries
bump..............
Old Apr 1, 2003 | 07:28 PM
rx7passion's Avatar
the whole thing? no, part of one and getting it to work yes!
i had both side by side and only difference was the return line size and that and the shape or the mount on the top. all i did was cut down the main pick up graft on the fuel pump and hook the wires up and isolate them. biggest problem i encountered was the return i used from the fuel rain was the fuel vapor line (stock) which has no tube down into the tank just a hole at the top.
with just using a stock gasket element it would spray gas and it would leak out the top. so i did some custom notching and used some hardening gas safe sealant and it worked. keep and mind i never got to use the car at fuel throttle boost, but it did work keeping my surge tnak setup full. anything else you would like to know? oh and i dont have any pics sorry
mazdaverx713b
48
Apr 21, 2016 06:45 AM
Alan777
Aug 13, 2015 02:47 AM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
