fixing cruise control?
Old Mar 28, 2003 | 10:43 AM
Question fixing cruise control?
What is the most likely cause of my cruise control not working in my 85 automatic rx-7? Is it most likely the cruise control switch or something else I should check?
Old Mar 28, 2003 | 11:11 AM
racermike's Avatar
aheadau
Have you "eyeballed" the mechanics? (vac hose, cable, etc)
Old Mar 28, 2003 | 11:43 AM
85RX7GS's Avatar
Re: fixing cruise control?
When was the last time you looked at the computer (underneath the driver side bin)?
When you turn the cruise on, does the red light come on? If the light does come on, will the 'set' button hold the car at a steady speed?
Old Mar 28, 2003 | 11:52 AM
brownmound's Avatar
Anytime baby!
Definitely check the vac hoses that operate the cruise. common for those to come loose...the little t-fittings will probably fall apart in your hands after 18 years.
Right on.
Old Mar 28, 2003 | 11:57 AM
web777's Avatar
As said above check the vacuum hose at the T. It is probably cracked since it's above the exhaust. That's what happen to mine.
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
