Caster Adjustment
Old Mar 27, 2003 | 12:01 PM
neil Gueldner's Avatar
Caster Adjustment
I have an 82 RX7 with lowering springs from RB that drop it by about 1 inch. I also installed poly bushings on the tension rods.
The trouble that I am having is the front lower suspension arms are not centered in the cross brace channel on the body. They actually rub against the front of the channel. It looks like I have too much caster. The tension rods are adjusted out as far as they can go. It seemed to get a little worse when I rotated the strut tops to get max negative camber.
Anybody else run into this problem? I had a mechanic who is not familiar with RX7's look at it, he didn't see anything obviously wrong.
Thanks
Old Mar 27, 2003 | 12:18 PM
racermike's Avatar
aheadau
Are your control arm bushings ok? Are you sure that you have no more adjustment on tension rods? Has the car ever been wrecked? I adjust mine right up to contact. The extra force to steer the car helps me slow down the movement and I think it gives you a little more dynamic camber.
Old Mar 27, 2003 | 12:41 PM
inittab's Avatar
I read your email
Does this happen on both sides? I suggest that you bring it to an alignment shop and have them accurately measure the caster. Seems like it's WAY off to me.
Old Mar 27, 2003 | 05:56 PM
Rx7carl's Avatar
Airflow is my life
put the strut top with the arrow in and back, thatll give you max neg camber and max caster
Old Mar 28, 2003 | 12:07 PM
The car has never had any frame damage - just a couple of minor fender benders about 10 years ago.
I had the car aligned when I installed the new springs - 3-4 years ago. I asked about that adjustment and I was told that it measured OK. I'm guessing that I should have gone to a better shop.
Anyway, it got worse when I rotated the stut tops a couple of days ago - so I figured I really should address the problem.
I have the arrows in and front. Does that give max neg. camber but less caster?
Thanks
Old Mar 28, 2003 | 01:18 PM
inittab's Avatar
I read your email
Arrows pointing in and back will give you max camber and max caster. The arrows should point towards the stick shift.
Old Mar 28, 2003 | 01:22 PM
jeremy's Avatar
male stripper
[i]I have the arrows in and front. Does that give max neg. camber but less caster?
Thanks [/B]
yes
Old Mar 28, 2003 | 03:28 PM
Rx7carl's Avatar
Airflow is my life
: Your caster is now swung to min caster, just rotate it and recheck it. That wont help your problem with the crossmember though. Im guessing your new tension rod bushings are too thick to get a good centering of the LCA in the crossmember.
Old Mar 28, 2003 | 04:33 PM
Thanks. I'll try rotating the struts. Maybe I'll pick up some new bushings too.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
LongDuck
Oct 7, 2015 08:12 PM
Sh00bs
Oct 1, 2015 11:57 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
