appropriate idle speed?
Old Mar 25, 2003 | 06:08 PM
thorin's Avatar
my 85 GSL idles at about 1000rpm... that seems kind of high. is that what everyone else is getting? do you think this is severely affecting my gas mileage?
Old Mar 25, 2003 | 07:43 PM
tubbymother's Avatar
ideally, 700 to 850 rpm, 1000 rpm does seem to be high
Old Mar 25, 2003 | 07:47 PM
FB II's Avatar
i can't get mine to go under 1100. :-/ it was at around 900 when i was running it way too rich,but now i have it running not too lean or rich, and it's at 1100. dont you just adjust the idle at the linkage facing the drivers side of the carb? or is it the one in front of the carb near the main pulley with the srping in it?
Old Mar 25, 2003 | 08:08 PM
PaulFitzwarryne's Avatar
Apprentice Guru
A wll tuned 12A will idle at 700 rpm. The offical specs are 750rpm plus or minus 25.
!000rpm is high but should not necessarily increase fuel consumption significantly. Ported engines are a different matter, I have seen a bridgeport not liking below 2000rpm.
Old Mar 25, 2003 | 08:51 PM
pratch's Avatar
Mazspeed.com
As you change the idle speed screw, you usually end up changing the fuel mixture screw.
it's a dance that should end up at 750, but usually ends up between 800-1100. If you're uncomfortable with it, reset them (making sure to write down how many turns out you were) and start from scratch - it's a game that goes on for hours that the whole family can enjoy!
Old Mar 25, 2003 | 08:58 PM
coldy13's Avatar
Yeah, shutup kid.
It's really not too hard, just two screws to play with. I have mine idling at around 650 now that it's summer. When it's winter I bump it up to 800.
Old Mar 26, 2003 | 12:57 AM
FB II's Avatar
but where is the idle adjustment screw? anyone got a pic? my haynes tells me but i don't see it there. is it something you adjust with a screwdriver like the air/fuel?
Old Mar 26, 2003 | 02:20 AM
thorin's Avatar
yeah, can someone post pics of which screws to turn?
Old Mar 26, 2003 | 06:39 AM
pratch's Avatar
Mazspeed.com
Pic cross-posted from here
http://mazspeed.bcrx7.com/forum/thre...847&boardid=44
Old Mar 26, 2003 | 07:52 AM
djmickyg's Avatar
thats a funny looking carb.
the 2 screws (idle and mixture) will be behind all the rats nest (if u still got it) there willl be and large and small screw.. the haynes manual does show it, im sure of it..
Old Mar 26, 2003 | 08:07 AM
pratch's Avatar
Mazspeed.com
it's a carb with a lot removed and it allows detail to be seen
Old Mar 26, 2003 | 09:09 AM
cheapie's Avatar
The Haynes manual says not to mess with the mixture screw on newer models. Plus, at least on mine, the mixture screw has a metal cover over it that I haven't bothered to remove yet. Mazda should trust us more. We know what we're doing.
Old Mar 26, 2003 | 02:29 PM
vipernicus42's Avatar
Rotoholic Moderookie
Stock Nikki: anyone wanna volunteer how many turns on each you're running? Just to give me a basis from which to start testing things for mine... never done any carb work before...
Old Mar 26, 2003 | 08:37 PM
pratch's Avatar
Mazspeed.com
FSM says 3 turns out is where you start.
Old Mar 26, 2003 | 11:32 PM
djmickyg's Avatar
i got mine on 3 1/2 and its running a lil rich.
which way leans it out, in or out??
Old Mar 26, 2003 | 11:35 PM
coldy13's Avatar
Yeah, shutup kid.
In for lean, out for rich
Old Mar 27, 2003 | 05:54 AM
Lt. Dan's Avatar
Mine will idle at 1500 when I come to a light, and then I have to put my toe under the pedal and pull up to drop it to 750... Any ideas what could be causing this?
Dan
Old Mar 27, 2003 | 07:04 AM
pratch's Avatar
Mazspeed.com
sounds like your accelerator cable is over-tightened.
Old Mar 27, 2003 | 10:43 AM
3 turns out on which screw tho? Mixture or speed? (assuming mixture since you're talking about rich/lean, but I just wanna make sure, who knows what could happen if I start messing with the wrong screw 3 turns out? Idling past redline.. hehe :P)
Jon
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
firzen
Sep 15, 2015 12:04 PM
The1Sun
Sep 7, 2015 10:21 PM
