Was this a good buy?
Old Mar 18, 2003 | 12:52 PM
ECU scanner
Been having some problems with the throttle and also wanted to get the TPS working poifectly...
Might have issues either with the ECU or the wiring harness.
Has anyone purchased one of these? Any comments??
Thanks!!
Old Mar 18, 2003 | 01:36 PM
pmr2000's Avatar
Looks like same as 2 LED's/3 spade test light you can make yourself from about $5 in Radio Shack parts. They mounted to a panel. If you get 2 LED's and 3 male 1/4 inch spade connectors you connect 2 positives to one spade, each negative to another spade.
Old Mar 18, 2003 | 05:26 PM
dont forget the guy who sells them on eBay for 25-35 bucks, and that is the OPENING bid!!
Old Mar 18, 2003 | 05:43 PM
sunshine's Avatar
Yup, I made my own. Probably cost me $3-$4, and 30 minutes of my time. radio shack is good like that.
Old Mar 18, 2003 | 05:57 PM
Drifter101's Avatar
Back from the dead...
Thats not bad, im going to look into how these guys made there own allthough
Old Mar 18, 2003 | 06:26 PM
If this woman can make one- so can you :-) Take a look at TeamFC3s.org. I believe the instructions are located there. One note: Use different colored LED's. Good Luck!
Old Mar 18, 2003 | 06:59 PM
Dvst8's Avatar
Going for the win
i made mine with 2 LED's and three 2inch wires. easy
Old Mar 18, 2003 | 09:46 PM
I reccommend that you solder the connections, just to be safe, but I have even seen people splice the wires and tape them....ghetto when the right way is so simple, but hey it works....hell, I would even make one for you if you want.....let me know
astrum
24
Nov 15, 2017 08:44 AM
bURGRotary87
Aug 19, 2015 03:54 AM
cam_7779
Aug 18, 2015 07:48 AM
