my rx7 wont start help!
Old Mar 16, 2003 | 04:55 PM
frankr7's Avatar
problem starting my car please help!!
1990 rx7 convertible
i was replacing some hoses from under the intake manifold when i created a smoke near the the right side of the engine. i forgot to disconnect the battery but anyways i found out that my main fuse had just blown because of that so i replaced it with a used one. I put everything back together when i happened to break off the green plastic tip of the injectors but continued to put everything back together.all this tok a few days took a few days to do bythe way.well i got back in the car it would crank but not start up, i tried it many times. then i checked and charged my batery then went to see if i was getting spark and did but when i cheked my spark plugs they were all wet with black fuel, by the way i happened to buy spark plugs 2 months ago. well anyways i found out that my car was flooded so i did the unflooding procedures where i took off plugs cleaned them very well added atf to bottom holes to build compression then took off egi fuse and an extra fuse then got in car pressed accelerator dowwn and cranked for 15 secs. then put everything back together and cranked like it almost wanted to start but did not. i did these same procedures all over again 12 times but still wont crank all the way with my batery charged fully. idont know if i should continue to do this. also i checked my secondary injectors and they kinda move and fuel come out a bit.
if anybody knows anything about this please help
Old Mar 16, 2003 | 05:21 PM
dr0x's Avatar
pei > caek
Your secondaries shouldnt be firing when trying to start. You just found out why its flooding anyways. I would just pull/push start it. Easier than dicking around pulling spark plugs etc.
Kyo
Apr 13, 2019 09:24 AM
Th0m4s
Feb 26, 2019 02:04 AM
Jutta_J
Mar 25, 2017 11:24 PM
86glxNA
Aug 18, 2015 03:33 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
