What to use for turbo oil/return lines?
Old Mar 15, 2003 | 02:48 PM
chris_stampe's Avatar
Hey,
Can I use rubber lines for oil feed and return to my turbo? If not, what else should I use? Can I use something like this guy did?
Thanks,
Chris
Old Mar 15, 2003 | 03:52 PM
dr0x's Avatar
pei > caek
Id use stainless steel hose crimped onto the hard line.
Old Mar 15, 2003 | 09:48 PM
Well, I used some nylon braided rubber hose and double clamped the ****. We will see if it holds. Ill keep ya posted on how it works.
Chris
Old Mar 16, 2003 | 01:13 AM
White_FC's Avatar
dr0x is on the money with this one, I used rubber first with mine, stupid idea. Now have stainless steel braid which you should use for things like this because of the extreme heat is has to put up with.
Old Mar 16, 2003 | 07:04 AM
HeffBoost's Avatar
Keep Right Except to Pass
Wow, if there was ever a place to not "jury-rig" something, I would think this would be it. If the feed line goes, your turbo is right behind it.
Old Mar 16, 2003 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
To be perfectly honest, I used standard fuel injection hse and have not had any problems even at 90 PSI oil pressure. However, I do NOT recommend this. On my list of things to do before I put the car back on the road is to replace all that with hard line and braided stainless. The proper hard line and hoses are available from any hydraulic hose shop. They can even make the fittings for a plug and play application.
Old Jan 4, 2004 | 04:00 PM
nylon braided fuel hose with that chinese fingertrap **** over it to try and help with the heat......even on a oil only cooled to4b it works like butter
for over a year!
Old Jan 4, 2004 | 06:19 PM
Bambam7's Avatar
I came, I saw, I boosted.
I have been using 100psi fuel injection line for over a year now. Integrity of the hose is perfectly fine, but I've had some issues with wet hose clamps.
Old Jan 4, 2004 | 07:11 PM
razorback's Avatar
You've Been Punk'd
ill probably go with brainded stainless steel..match the rest of the stuff
Frisky Arab
13
Aug 18, 2015 05:30 PM
Kyo
Aug 14, 2015 02:00 PM
