Starter(motor) kill switch
Old Mar 15, 2003 | 12:35 PM
Aico's Avatar
1)Where do you put the switch?
I looked in the Haynes manual.(page 173)..is it X-10? BY->Black-Yellow wires. There is a Fusible link on that wire.
2)What's the max AMP going through that wire? Is a switch enough or do I need a relay?
Old Mar 15, 2003 | 09:30 PM
FD-less's Avatar
Wrong circuit. You can always push-start a car with a starter kill. Get the fuel circuit. For some god-forsaken reason Mazda didn't see fit to run the fuel pump circuit through a relay, so interrupt that circuit with a relay that only trips once you hit the switch.
My .02
Old Mar 15, 2003 | 11:11 PM
REVHED's Avatar
Hunting Skylines
Bettter yet, do the fuel, ignition and the starter.
Old Mar 16, 2003 | 03:41 AM
Aico's Avatar
I was planning on doing a starter buttonswitch and the fuelswitch with a remote.
Maybe it's a bit overkill.
For the fuelpump.....what wire do I need to cut for the relay? And howmuch AMP is going through the wire and relay?
Old Mar 16, 2003 | 05:18 PM
WAT BEN JIJ EEN KNEUS ZEG!!!
P.s how do i do it or my FC
( series 5 )
Bad **** sec gen!!
Aico TESTIFY!!!
Old Mar 16, 2003 | 08:38 PM
unreality's Avatar
Always broken.
( series 5 )
Bad **** sec gen!!
Aico TESTIFY!!!
Th0m4s
Feb 26, 2019 02:04 AM
The Shaolin
Sep 14, 2015 07:50 PM
befarrer
Aug 14, 2015 04:18 PM
