Sponsored by: CARiD
flooded 2nd gen S4 Rx7
Old Mar 13, 2003 | 06:56 PM
zlider's Avatar
Newbie
Anyone knows how to fix a flooded engine....RX7 2nd gen s4 N/A
Old Mar 13, 2003 | 10:56 PM
patience
just keep on turning over the ignition for about 10 seconds each time, and don't push the gas pedal. If it is a recurring problem, my local mazda shop designed a fuel shut off switch and I can probably get you one. If you still can't get it started after a while, clamp the fuel line until it starts, then unclamp it. Don't get used to doing that too much though
Old Mar 17, 2003 | 11:09 PM
White_FC's Avatar
...or you could just take out the fuse for the fuel injectors and crank it over with your foot to the floor to get all the fuel out, or if that isn't enough you may have to take out the spark plugs and spin the motor over.
Old Mar 18, 2003 | 10:07 AM
jeremy's Avatar
male stripper
you might have to put some oil into the motor via the spark plug holes to get the compression up. the gas will wash away the oil boundary reducing compression. there should be a few threads on the de-flooding switch installment. my car came with it already on from the previous owner. you can also use the egi fuse method like white fc said.
R7rexy
19
Sep 2, 2015 10:24 AM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
86glxNA
Aug 18, 2015 03:33 PM
