Do Gullwing doors work on original fenders ????
Old Mar 13, 2003 | 06:20 PM
ICE_Pilot's Avatar
V8-TZR
Hey I have been looking at pics of the RE-Amemiya gullwing doors.....it seems like you need wider fenders to fit all the hydralics in......Dose anyone know about this or can they give me info on it.
Like for example would those door work with original fenders and the GTC side skirts ?
http://www.steveprew.com/~rextreme/2...re-green-3.jpg
http://www.steveprew.com/~rextreme/2...re-green-2.jpg
Old Mar 13, 2003 | 07:09 PM
Mahjik's Avatar
Mr. Links
The older RE car isn't using a wide body kit for the door. I don't think that it necessary depending on the type of door you have.
Old Mar 13, 2003 | 08:56 PM
ICE_Pilot's Avatar
V8-TZR
Yea thats what I thought.....I have pics of the blue one and it never had wide fenders on it. What do you mean by the type of door you have ???
Old Mar 13, 2003 | 09:31 PM
Mahjik's Avatar
Mr. Links
I believe they make gull wing doors that come out to the sides then up, or ones that sort of just "go up".
Since I've never seen any of the FD gull wing cars in person, I couldn't tell you. Only going by what I've "heard".
Old Mar 13, 2003 | 11:38 PM
ICE_Pilot's Avatar
V8-TZR
I recon it wont look so cool on some bodykits.....but aye who knows.
Old Mar 13, 2003 | 11:43 PM
T88NosRx7's Avatar
has anyone every heard of a price for these?
Old Mar 14, 2003 | 01:57 AM
n2trbl's Avatar
Pro Drummer!
Ditto..... I too would like to know.I've seen kits for civic's and that, to convert your stock doors to gullwing doors. I think 7's look sweet with them. Probably because I'm a huge lamborghini fan so I'm kind of bias when it comes to them.
Old Mar 14, 2003 | 02:34 AM
ICE_Pilot's Avatar
V8-TZR
Aye n2trbl...what ever flotes your boat man...if you can find a kit..let me know.
Old Mar 14, 2003 | 03:58 AM
Ethan RX-7's Avatar
Well, technically, those are scissor doors... gullwing doors are hinged at the top of the windows and swing out like wings.
Ok, I don't know a lot about the RE doors, but I believe the ones on the camo FD are hydrolic and completely automatic (push a button, doors open) where as the blue FD's doors are more manual (lift door up by hand).
If you look closely at the blue FD you will notice that the vent behind the front wheel is gone and in it's place is just a little indention suggesting it (most likely just to blend in with the lines on the door itself). I believe this is because of the mechanism for the door. So, I doubt it would work with stock fender.
Old Mar 14, 2003 | 08:04 AM
Mahjik's Avatar
Mr. Links
RE charges around $12k I believe for the conversion (but of course, you car has to go to them, in Japan). There is no kit. I'm not sure if RE uses the stock doors for the conversion or CF doors.
In the US, you'll have find a custom shop and you are still looking around $12-15k for the job.
There is a reason not many FD's have that done, and it's because it's damn expensive.
Old Mar 14, 2003 | 08:35 AM
Gorilla RE's Avatar
GorillaRaceEngineering.co
Ethan RX-7 ""but I believe the ones on the camo FD are hydrolic and completely automatic (push a button, doors open) where as the blue FD's doors are more manual (lift door up by hand)."" your 100% right. the door kit tha RE
Amemiye sell is hydrolic and does cost 12K. but you can't
get theme in the states. you have to bring your car to Japan and have RE put them on the 7 for you, they won't ship the.(that sucks) that means 12K doors + 3K trip = to much to spend on doors, no matter how bitchi'n they look.
Old Mar 14, 2003 | 08:36 AM
Gorilla RE's Avatar
(Amemiya) I'm an idiot
Old Mar 14, 2003 | 09:57 PM
ICE_Pilot's Avatar
V8-TZR
Well it dosent look like they will fit in a garage or some under ground parking...or maybe they will...who knows.
Old Mar 14, 2003 | 10:06 PM
93BlackFD's Avatar
built my own engine
heh, my friend is a mechanical engineer, he designed some on cad and had a machine shop do most of the brackets/metal pieces, total project costs was less than $1500
he has them on his VR-4 spyder
Old Mar 14, 2003 | 10:22 PM
Mahjik's Avatar
Mr. Links
Not to knock your friend or his work, but I'm sure doing it on a VR-4 vs a FD is a night and day difference. I'm sure he had a lot more area to work with for the installation. The FD is qutie a bit smaller, and from what I hear, most of the work is hacking up the body and reinforcing it to support the doors and the hinges.
I doubt the actual parts would run all that much (maybe $1500 - 2000 per door, if that).
Old Mar 15, 2003 | 10:13 AM
Resource's Avatar
Complete Lambo Style Door Modification 6,000 less paint.
Bi-state Customs does this fabrication for 6,000 for both doors without paint. 618-234-0069
Old Mar 15, 2003 | 10:26 AM
n2trbl's Avatar
Pro Drummer!
I have a body shop near by and this guy does some kick *** work. I should be going down there today and I'll ask him how much $$$ it would cost to do the job. Both with and without paint. ice pilot I didn't mean I was going to buy a kit to convert the doors. I was stating that this company (decah.com or something like that)makes them for civics, integra's and I think a couple of other cars too... And it is a direct bolt on kit and it only takes a few hours to install plus they claim the kit "cost less than a set of new rims" I was just saying that maybe a someone else could make or has made a kit similar to this. The kit could be total crap I don't know but I do think it is possible to get if cheaper than 12k. That's overkill if you ask me. And the pic of the blue 7 above just has aftermarket fenders on it. It's not like they modified the fender to get the doors to work. So I would tend to believe that the doors would work with the stock one's. I don't know. Oh by the way... I'm not flaming or mad or anything. I just don't want anyone thinking I just went off or anything.
Old Mar 15, 2003 | 10:31 AM
Mahjik's Avatar
Mr. Links
If you look at the blue RE car above, the door looks completely different then stock driver's side interior. I would say that either the door has been modified for the conversion or they used CF doors.
Old Mar 15, 2003 | 12:34 PM
ICE_Pilot's Avatar
V8-TZR
You know what fellas....after all this I think its just not even worth the bother. Looks good and all but I think Ill pass.
Old Mar 15, 2003 | 09:17 PM
Gun's Avatar
Gun
I don't think the orginal doors are used because they are ti heavy and it would require a lot of reinfiorcement. I think they use a set of PanSpeed CF doors, you can order them(not sure the price 1000-2000 a piece I think) and I believe a shop in Flordia will install them scissor fashion for about 3500-3000 a door. Sweet if you ask me and if I had the money I'd get doors like that.
Later Gun
Old Mar 16, 2003 | 01:09 AM
ICE_Pilot's Avatar
V8-TZR
Thanks for the info Gun.
Old Mar 16, 2003 | 08:06 AM
Mahjik's Avatar
Mr. Links
Later Gun
The Panspeed CF doors are $3100 a piece:
http://www.jt-imports.com/Panspeed%20FD.htm
That shop down in Florida, I'm not sure if they are still in business. Their website has been gone for over a year and I have not been able to locate any other contact info on them. However, to my knowledge, they had never actually done the conversion on an FD. They had only estimated what it would cost (which was around $3500 per door without the price of the CF doors).
Old Sep 5, 2003 | 07:51 PM
carexcess's Avatar
Newbie
I am looking for a volanteer to bring in your 1993 - 1997 Mazda RX7 so I can finish creating the lambo doors for that vehicle. The car must be a car that has not been in an accident.
Check out my site. http://www.carexcess.com/vdc
I am offering this kit at $800 off normal installed price.
This modification will cost the volunteer $1500 and will look just like the picture http://www.re-amemiya.co.jp/retuden/...dy/greddy5.jpg
Normal retail price $1900 and installation will be $300 - $400.
More information is available at http://www.carexcess.com/vdc/
Please call me at 727-585-7878
