MAX BOOST with an FCD and additional injectors
Old Mar 6, 2003 | 08:26 PM
TURBO 2 managment, if i put a Fuel CUT and extra injectors how much boost can i safely run
Old Mar 6, 2003 | 08:37 PM
Cheers!'s Avatar
Former Rx7 *****
so stock copmtuer? i would say 8 psi... if you get some sort of piggy back comptuer (ie Apexi safc, greddy emanage) i would say 15 psi.
beyond that you should really get a nice standalone... like Autronic or Haltech
Old Mar 7, 2003 | 01:52 PM
hondah8er's Avatar
mazdaspeed 3 coming soon
Ummm if you put a FCD in you can safely run alot more than 8 lbs. I was running 14lbs for a year straight
Old Mar 7, 2003 | 04:21 PM
HeffBoost's Avatar
Keep Right Except to Pass
If you're talking about "extra" injector and have management, then probably up to what the turbo & IC can take. Some say 12, some say 14. I believe anything over 10 is out of it's efficiency range. Running 14 on it consistantly will have it puking seals after a while.
Just my two cents.
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
Snook
21
Sep 1, 2015 06:32 PM
TerryD
Aug 23, 2015 07:40 AM
Snook
Aug 15, 2015 08:18 AM
