42mm offset on FC?
Old Aug 19, 2001 | 09:52 PM
Ridge Tech's Avatar
42mm offset on FC?
I'm new to the world of rims, I'm not sure what the stock offset is but I was wondering if anyone knew if a 42mm offset would be ok with 17X7.5 5-100/114 42mm on a FC? I have 225/50 16 on my TII rims right now and they clear the front spring by less than an inch. I know that I can't run my drop springs with them unless I use my 5mm spacers. I'm trying to stay way from the spacers tho. Thanks, Chris
Old Aug 21, 2001 | 02:54 PM
ARD T2's Avatar
You should be fine with that offset. In fact you should be able to slam it with the 7.5's. It will fit and I don't see why you would have a problem with doing the drop springs, unless you are rubbing on the inside lower spring perch.
Good luck, Rishie
AUto RND
doritoloco
Sep 17, 2015 03:51 PM
