A TII Question
Old Aug 19, 2001 | 03:55 PM
A TII Question
What made the TII put out more HP in 1989 was an improved exhaust manifold right? Well if you take a pre 89 TII and replace the exhaust manifold with a header wont you get the same effect? Or were there other differences.
Old Aug 19, 2001 | 04:30 PM
vaughnc's Avatar
knowledge junkie
The rotors were lighter/higher compression as well and yes you can put them in a 86-88.
Old Aug 19, 2001 | 07:07 PM
fc3s.org's Avatar
OG
Re: A TII Question
The 89+ motors had lighter rotors and higher compression. They also had a better turbo, with a more efficient wastegate, better manifold with no twin-scroll. The IC was larger as far as the hot side pipe went, but the core size is the same. I also believe that the intake runners are longer and better designed for more/better airflow.
The TII's can't have headers as the turbo feeds from the exhaust manifold. The things listed above, along with more I am sure, are the reasons for the HP differences.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
Nosferatu
Sep 5, 2015 02:13 PM
