Performance and exhaust question(s).
Old Aug 18, 2001 | 08:32 AM
punkncat's Avatar
I have an 86 GXL powered by an 88 engine and computers(as if that makes any differance). My buddy has an 88 GXL. He recently changed his exhaust to a 3" straight pipe from the reactor to the Y pipe.His mufflers have been changed to a higher flow design also.He still has the stock airbox , etc. The only modification I have made to mine is to gut the main cat. I also have my heater core bypassed(does that matter?) and air taken out. Before either of us changed anything about our cars , they would run dead even.Now with the mods he has made I would expect his car to be faster, but we still run dead even. Why would I still be just as fast?
Old Aug 19, 2001 | 08:55 AM
SuperchargedRex's Avatar
Chief Knucklehead
And unless you've both found an alternate method for opening up your six ports, you're both missing a lot of top end power. The '88 motor uses backpressure from the exhaust to open them, and with either a 3" pipe or a gutted cat, you won't generate enough backpressure. Check out this page from Travis Shrey's website on how to work the six ports. Don't tell your buddy, and you'll be able to kick his butt.
Old Aug 19, 2001 | 12:53 PM
punkncat's Avatar
Both our 5-6 ports work just fine.He capped the end of his air feed for the cat and they actuate just fine.Mine never stopped working.
cristoDathird
28
May 30, 2019 08:47 PM
astrum
24
Nov 15, 2017 08:44 AM
82streetracer
Aug 23, 2015 09:28 AM
12abridgeport
Aug 17, 2015 06:28 PM
