87 TII starts up on 1 rotor???
Old Aug 17, 2001 | 05:10 PM
HAILERS's Avatar
HAILERS
Sounds a bit like one of the injectors is leaking after you shutdown. I'd try, at the end of the day, running the engine and while its running pull the fuel pump connector off so that the car dies. There should not be any pressure in the fuel rail now so the injector should not leak in the rotor . Get up the next morning and reconnect the plug and start the car. If it does not act up like before its probably a leaking injector. There are several ways to disable the fuel pump. That was just one of many.
Old Aug 18, 2001 | 02:12 AM
Keith's Avatar
Unhappy
CRazyJOker, are you losing coolant from the radiator? I would suggest that you crank it over a few times without starting it, then pull the bad rotor plugs. Are they wet? If so, with gas or water? if they are dry, crank it some more and see if anything is sprayed out from the bad rotor. Gas is an injector problem, water is a seal problem. Good luck!
Irv, Keith's dad
Old Aug 18, 2001 | 02:16 AM
Agent_D's Avatar
rawr
wow, sounds kinda like my car, except my car is blown it will start and run on 1 rotor, sounds kinda cool too but it shutters horribly at idle, i dont know if a apex seal broke or not, the OMP metering rod came off the TB and thats how i think it blew, i poured some atf in there and it didnt seem to help, any other suggestion??
Old Aug 18, 2001 | 03:19 AM
GTR's Avatar
GTR
mine does the same thing. my car is dead. i start it just to move it some where else and thats it. it had some flooding problems before .. ::sigh:: .. im hoping to get a jspec soon. I NEED ONE.. i havent drove my lovely RX7 in like 4 months.. ::sigh:: crys
Old Aug 23, 2001 | 09:52 AM
Turbocharged's Avatar
sounds just like my 91 TII, except I don't get the smoke. However I am gradually(over a period of like 3 or 4 weeks) losing coolant. I have to add some water to the radiator keep it from overheating (even the the overflow bottle stays full all of the time) Kind of strange if you ask me.
-nathan-
Old Aug 24, 2001 | 04:01 AM
JohnL's Avatar
Ok, sounds like a fuel problem.. trust me, I've been through very tough times with my turbo II and now it runs great. My first question is you said you had a shop/mechanic check your injectors and they were good?? Please tell exactly what they did? Did they pull the injectors and flow test them?? All it takes is one leaking injector and you've got problems. I would also check your water thermo sensor thats on the back of the water pump.. check the connector first and ensure it is in good shape. If possible, get a code checker on the car and see if its pulling any codes. My guess is you have a leaking injector.
Old Aug 24, 2001 | 05:06 AM
i had the same sort of problem on my N/A, i was told the oil seals had gone and that it needed a rebuild..
i said stuff that and got a turbo.. :P
Old Aug 24, 2001 | 07:33 PM
Suparslinc's Avatar
It's Back!
well here my theory, take it for what its worth.
You might have a bad spot in one of your water seals. As the engine housings heat up, they expand, and this might allow your engine to seal properly.
If its cold, then you have a bit of a coolant leak when the engine first starts. The rotary is built with alternating layers of iron/aluminum, so until they all heat up to running temperature, they are expanding and contracting at different rates.
I would start thinking about a rebuild, in the meantime, take it easy while your car is warming up and let it cool down for a few minutes too.
Old Aug 25, 2001 | 09:27 AM
Fingers's Avatar
for what its worth, i have the EXACT, and i mean EXACT same problem. My car does that when its hot/cold. This started happneing a couple of days ago and it scared the **** out of me. So i'm trying to sell the car as-is as fast as i can.
i'm just looking for solutions on how to bandaid this without rebuilding the motor, because lets face it, not everyone has $1000 to spend on a motor rebuild
Old Aug 25, 2001 | 12:02 PM
Fingers's Avatar
If you find a way to temporarily fix this problem, plz let me know. I was thinking of putting rad stop-leak in ... but i'm afraid of what it might do if it will fall into the combustion chamber. Either way, i have to sell the car right away. I know its kinda immoral, but hey, thats why i'm selling it as is local rx7 shop is charging me $1G to rebuild it if i bring them just the shortblock. If i decide to shell out the grand, then i'll keep the ******* thing. Lemme know if you run into any solutions plz
thanks
-Ross
cristoDathird
28
May 30, 2019 08:47 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
