Double Battery Question
Old Feb 17, 2003 | 08:08 PM
Matty's first 1st Gen's Avatar
Boosted 7
Hey guys this may be a dumb question but i was just wondering if i added another battery to my car and ran them in parallel if it would make a difference at all, I thought that it may supply a few more amps maybe for easier starting, or whatever. If anyone has any thoughts on this i would apreciate it
~Matt
Old Feb 17, 2003 | 08:10 PM
RotorMotorDriver's Avatar
Seven Is Coming
It would add more weight than I would see a need for. Unless youre hardcore into car stereos and you need the extra power, I dont see the point.
~T.J.
Old Feb 17, 2003 | 08:26 PM
Boosted 7
well i am running a 500s rockford fosgate amp, with 2 12 inch Jbl's
Old Feb 17, 2003 | 08:45 PM
djmickyg's Avatar
it wouldnt be worth it, just spend ur money and get 1 decent sized battery or even a dry cell one..
Old Feb 17, 2003 | 08:50 PM
85RX7GS's Avatar
~T.J.
Ditto. You only need one good battery. If you're concerned about power to your stereo system, then maybe you ought to strap on a high output alternator.
Old Feb 17, 2003 | 09:05 PM
damn hippies
a high output alternator isnt needed..just a fraid cap that will handle the power of your amp....
Old Feb 17, 2003 | 09:08 PM
Seven Is Coming
A lot of people say that capacitors are just a band aid for a problem. Hint, hint .
~T.J.
Old Feb 17, 2003 | 09:16 PM
damn hippies
ive ran a 1200 watt amp and a kicker 240 w/o another battery or copasitor....the compasior does nothing but give the amp a full 12 volts of power...when people run there remote wire from the back of the deck to the amp its not getting a full 12 amps its getting about 10-11...there is 2 ways to get 12v...a compasitor...battery...or running your remote wire from your battery to a switch to your amp...its all the same
Old Feb 17, 2003 | 09:20 PM
bliffle's Avatar
The low battery will drain the high battery. Don't do it. Why do you need so much amp?
B
Old Feb 17, 2003 | 10:34 PM
Manntis's Avatar
add to cart
only reason for such a setup (common in some Chevy pickups) is for higher cold cranking amps (read: starting a V8 in -40 degree weather)
Old Feb 18, 2003 | 01:49 PM
Narcisse91's Avatar
The capacitor supplies a quick release of current to the amp if there is a peak in current draw. Then, it draws current from the alternator (cutting in on the amp's supply) to recharge. Only a band-aid. It's a much better idea to make sure you have an electrical system capable of supplying enough power.
Old Feb 18, 2003 | 02:10 PM
Seven Is Coming
What he said .
~T.J.
Old Feb 18, 2003 | 05:57 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Im not sure why you would want to, you should have no problem starting it with one battery. But if you do run two batteries in parallel , you SHOULD (im not gonna say must) use 2 identical batteries, preferably from the same group of batteries (purchesed the same time) or else they will try to kill each other charging and discharging one another.
Also if you run multiple batteries not side by side, but put another in the back, be sure to use large cable (1/0 awg or better) and run a HUGE circuit breaker at each batteries postive (250amp or so)
Old Feb 18, 2003 | 06:04 PM
jeremy's Avatar
male stripper
mike, the audio/elec wizard.
these cars don't take much to start. ever push started one? i could push v8kilr and get his started and i'm 5'7" and 125lb. if you are draining one to quickly then get an optima and get a better alternator.
Old Feb 18, 2003 | 07:11 PM
Turbo12A's Avatar
MR. Car Toys here says, "You only need one battery" Enough Said.
Old Feb 18, 2003 | 07:25 PM
mar3's Avatar
Administrator
So make sure it's an Optima... quality and all... ...to fix the crutch regarding power, this is your cheapest route with the least amount of hassle...
The Ultimate Alternator Swap Thread...
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
RPOdesign
Aug 27, 2015 11:42 PM
