different fuel pump?
Old Feb 14, 2003 | 11:07 AM
Thumbs up different fuel pump?
Im putting a sidedraft mikuni on my 84 gs and I was wondering if I need to upgrade my fuel pump and put a regulator. I asked atkins rotory and they told me I don't have to. But from what iv'e been reading it sounds like I need to. Any input would be appreciated.
Old Feb 14, 2003 | 11:56 AM
damon's Avatar
I would recommend up grading (the reason your upgrading your is performance right?) because that tired old stock pump is putting out unknown results and I wouldnt trust stock pressure # for the pump whereas it is ~20 yrs old more then likely
peace
Old Feb 14, 2003 | 01:19 PM
what would you suggest for the fuel pump and regulator?
Old Feb 14, 2003 | 01:24 PM
damon's Avatar
I personally am running a holley red and a holley .5-5.5 regulator with a stock nikki. many other use a carter fuel pump and regulator.
they are all kind of noisey but work great jest remember to get a gauge to go with the regulator so you can tune it
peace
Old Feb 14, 2003 | 09:40 PM
Newbie
I would definitely have to recommend a Mallory fuel pump.
Old Feb 15, 2003 | 03:14 AM
79+80_rx-7's Avatar
Well Mar3 HIGHLY recomends a carter, did you know that?
Hehe....
Old Feb 15, 2003 | 03:16 AM
79+80_rx-7's Avatar
But, on a serious note, get a Mallery!!!
Old Feb 15, 2003 | 07:54 AM
mar3's Avatar
Administrator
Before sterling goes into a frenzy about posting on someone else's computer acting like a different person, I should explain the obvious....mar2 will be my Dad whom I registered last night....the above recommendation was a test post to show him how it all works....I still HIGHLY recommend the Mallory Comp110 and its standard billet regulator....if this pump can keep up with bracket 427 cid mouse blocks on the track, there is no way any streetable rotary will get ahead of it....gerotor technology is ahead of vane-style pumps,,,,and they're prettier, too...bling, bling...
Old Feb 15, 2003 | 08:30 AM
Sterling's Avatar
Nikki-Modder Rex-Rodder
Ehhh.
Mario, we've jokingly gone back and forth on this for a year. Only a little funny, anymore- kinda like watching a tennis match- your neck's bound to get a kink in it!
...So let's spice it up a bit:
"You SUCK!"- How's that?!
No, Mr. Aguire- I'm very much kidding! Your son, Mario is a valuable book of knowledge for this board! (And, of course, 'Welcome to Rx-7 Geek Heaven!')
Mar3- How does the price of your favorite pump compare to the obviously cheap (but widely excepted as better than "good enough") Carter?
Someday I'll take your advice. But for most guys, I do believe price is a factor.
Old Feb 15, 2003 | 08:32 AM
Rx7carl's Avatar
Airflow is my life
Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter. Carter.
Old Feb 15, 2003 | 09:24 AM
TheTwinTurboRX-7's Avatar
what carl said
cheap yet effective
Old Feb 15, 2003 | 10:00 AM
Sammymatik's Avatar
Here we go again!
Old Feb 15, 2003 | 10:43 AM
Sterling's Avatar
Old Feb 15, 2003 | 05:10 PM
mar3's Avatar
Administrator
sigh...cheapos...OK, I'll lay off for a while, but it's real hard when you see the subject pop up each time like no one has ever answered the question before....real hard...
Old Feb 15, 2003 | 05:14 PM
Rx7carl's Avatar
Airflow is my life
Am I getting through yet? : We 1st gen guys are cheap bastards. Function over form wins everytime.
Old Feb 16, 2003 | 05:05 PM
31rx7's Avatar
Along with the pump and regulator (regardless of brand), replace the fuel line with a larger diameter - 5/16 should do it.
Old Feb 16, 2003 | 10:53 PM
mar3's Avatar
Administrator
Are you getting this, Manntis, Perez and pittdp?? Not to mention the cruel DF....
Old Feb 27, 2003 | 03:06 PM
poweRX-7's Avatar
been searchin through all these posts, and no one has yet to mention which carter they would use. for a stock setup would be preferable
Old Feb 27, 2003 | 03:46 PM
Kouki_1st_Gen's Avatar
im using holley blue with a regulator and performance wise, i have no complaints at all. i had a fuel pressure guage sticking out of the hood so that i can see the guage while im driving. on the freeway, i have floored my car all the way to redline up to 5th gear. the pressure stayed constant at 4.5psi, which is wut a want. the thing is... the damn fuel pump is way to loud... i like my car nice and quiet and the only thing i want to hear is the pure sound of music comming out of my rotary engine. dont realy wanna hear a nasty humming noise commin out of my fuel pump. do u guys know any fuelpump that will put out 4.5psi and stay quiet at the same time???
REVHED's Avatar
Hunting Skylines
The 7psi Carter Silver will flow more than enough.
Old Feb 27, 2003 | 03:50 PM
REVHED's Avatar
Hunting Skylines
Kouki, I've tried the Holley as well and the Carter is a lot quieter... probably due to fact the mounting system is way better. Some people complain about the noise but I really don't have a problem with it. In fact when the engine's on I can barely hear it.
Old Feb 27, 2003 | 04:08 PM
great! thanx for the info. about the mounting, ive added about 1/2 inch of more rubber. ive also wrapped the fuel pump with alot of foam, sponge like matterial. it was still very loud. my pump is the loudest part of my car.... well, imma ditch the holley and try the carter.
Old Feb 27, 2003 | 04:11 PM
http://store.summitracing.com/produc...earchtype=ecat
btw, which one of these carter r u using revhed?
Old Feb 27, 2003 | 04:34 PM
poweRX-7's Avatar
any recomendations on a regulator for the 7psi carter? would this pump work well for the stock nikki?
Old Feb 27, 2003 | 07:14 PM
mar3's Avatar
Administrator
cheapos........................................... ...................
