Bored - want to see if I can remember all my mods
Old Aug 16, 2001 | 07:57 AM
BOOSTD 7's Avatar
Persona non grata
Like the title says, it's 7am and I'm already bored at work. I'm going to try and see if I can come up with the entire list of mods on my 87 Turbo:
Engine
Large streetport engine w/3mm Hurley race seals, cut cooling jackets, B-REW rotors, all the goodies
B-REW upper intake, lower intake, throttle body
Wolf 3D engine management system
Custom front mount IC with all aluminum piping
60-1 Hi-Fi turbo, P trim, .96 A/R, tangential undivided manifold
Cartech cast turbo manifold
Turbonetics wastegate
Greddy Type R BOV
850cc primary, 1600cc secondary injectors
All custom 3.5" straight exhaust with X-Tec muffler
Pipercross air-filter with custom ram/cold air setup (filter mounted where passenger side headlight used to be)
Fluidyne radiator
Greddy Profec A boost controller
Magencore 10mm wires
Malpassi fuel pressure regulator
Aerodyne 1000hp external fuel pump
SX racing fuel filter
RPS 'carbonite' clutch
Mazdaspeed short shifter
Suspension/Brakes
Tokico Illuminas
Custom coil-over setup, 550 lb/inch front, 350 lb/inch rear springs
Camber/caster adjust front plates
Rear camber link
Replaced all bushings with Delrin/Urethane
Brembo cross-drilled/slotted rotors
Hawk blue pads, Motul fluid
Custom dual brake master-cylinder setup with balance bar, proportioning valve, tilton pedal assembly
Suspension Techniques front sway bar
... but still no rims yet, having trouble picking out the 'right' ones
Interior/Exterior
Bright *** Purple metallic paint
Border type II nose, Mariah wider front fenders, 89-91 rear bumper and side mouldings
Painted engine bay - very clean
Shaved all turn signal lights, antenna, rear brake light
Custom 7pt roll cage
Corbeau Forza seats with 5pt harnesses
Defi gauges and link, boost, EGT, fuel pressure, and tach
Wolf EMS air/fuel meter
Lexan rear window, front window soon
Road race fuel cell installed, 1/2" fuel line to engine
Sparco hood pins
Momo steering wheel
Misc
Optima battery behind passenger seat
Lots of weight savings, car was 2560 last year ... should be less now
Fire extinguisher
Spot welded along seams in front unibody
Removed and painted all the rear end stuff - diff, axles, subframe, etc
I'm sure I'll think of more
Old Aug 16, 2001 | 01:30 PM
BOOSTD 7's Avatar
Persona non grata
Nobody cares about my addiction
Old Aug 16, 2001 | 01:37 PM
Redwood's Avatar
Find Racing
I'm impressed.
Out of cuiousity, what kind of numbers are you posting? (ie 1/4, 0-60, 60-0, hp, lb-ft, etc.)
Old Aug 16, 2001 | 02:06 PM
BOOSTD 7's Avatar
Persona non grata
Uhh, no numbers yet ... but soon. It's still kinda in pieces. It's been a 3+ year long project.
Old Aug 16, 2001 | 09:03 PM
fcturbo2's Avatar
So you have all the parts but not actually hooked up in the car yet?..wow!..im going thru the same **** man!..I have bunch of go fast stuff that are collecting dust. They are waiting for a new motor. HEHEHEHE
Old Aug 16, 2001 | 09:22 PM
TonyTurboII's Avatar
Glock Lover
Re: Bored - want to see if I can remember all my mods
Pipercross air-filter with custom ram/cold air setup (filter mounted where passenger side headlight used to be)...
Got a link to this? Ive been trying to take in as many intakes as I can, then making a choice.
Old Aug 16, 2001 | 09:33 PM
BOOSTD 7's Avatar
Persona non grata
Well, my stuff isn't collecting dust anymore ... My target date is Sept 8th to have the thing on the road. I have about 100 hours and $5000 to go still. But the wife has ok'd it so far.
Old Aug 16, 2001 | 09:35 PM
BOOSTD 7's Avatar
Persona non grata
Re: Re: Bored - want to see if I can remember all my mods
Not yet, you could run out to the body shop with me Saturday morning to see it for yourself. The only thing is that you can only do it if you remove the stock headlight assembly. Me, I just pitched the headlights completely Who needs 'em. Basically, if it doesn't make the car go faster, it's gone.
Old Aug 16, 2001 | 09:36 PM
I'm very interested in your addiction....I'm just soo green w/ envy that it took me a little while to post.(Took about 5 hours to mop the drool off my desk and floor)
Nice mods...let us know some numbers when you get a chance.
Old Aug 16, 2001 | 10:09 PM
BOOSTD 7's Avatar
Persona non grata
I'll have my first round of pics this Saturday ...
Old Aug 16, 2001 | 10:26 PM
turboedRX-7's Avatar
Congrats on a great car! Let us all know how its coming! I now have a 88 T2 that I am starting to do some things with. Its going to be fun!
Happy motoring!
PS: How can I change my sig to reflect my new car & mods? Thanks much!
Old Aug 17, 2001 | 12:49 AM
Felix Wankel's Avatar
Super Newbie
Did you change the shade of purple?
Old Aug 17, 2001 | 06:24 AM
BOOSTD 7's Avatar
Persona non grata
Slightly, a bit darker with more saphire blue pearl in it.
Old Aug 17, 2001 | 11:29 AM
Driftfc3s's Avatar
Final Form
Well here's a small mod list of my car that I can remember...
Black 1990 FC3C Convertible RX-7
Engine:
-Stock N/A 13B (awaiting JDM 1990 13BT)
-HKS Super Power Flow (red)
-Custom Cat-Back exhaust with 2 Blitz NuR Spec Style Mufflers
-Free Flow cat
Ignition:
-Racing Beat Ultra 8mm wires
-HKS Spark plugs
-Optima Gel Cel Battery
Suspension:
-KYB shocks (front)
-Tokico shocks (rear)
-Tanabe Super Down Precedeo Springs (2" drop)
-Trust Front strut tower bar
Brakes:
-Brembo cross-drilled and slotted rotors
-PBR/Axxis Metal Master brake pads
-Goodridge G-stop stainless steel brake lines
Wheels:
-H&R wheel spacers
-17x 7" silver Mazda Millenia S rims
Interior:
-Autometer dual and single A-pillar gauge pods
-Autometer ultra lite fuel pressure gauge
-Autometer ultra lite voltmeter gauge
-Autometer ultra lite vacuum gauge
-Autometer ultra lite air fuel ratio gauge
-Autometer ultra lite transmission temp. gauge
-Autometer ultra lite oil temperature gauge
-Apex'i Rev/ Speed meter
-Apex'i S-AFC Air flow controller
-Greddy Turbo Timer
-Various Option 2 Stickers
-2 fire extinguishers (for the flames)
-Works Tuning Mazdaspeed Shoulder pads
Exterior:
-Turbo II hood
-Stock T2 Side Skirts
-Stock T2 Front Lip/Vanity Skirt
-Various Option 2 stickers
Lighting:
-Hella H4 headlight conversion
-Pivot Headlight controller (for lazy-eye effect)
-Raybrig bulbs
Coming soon:
-Apex'i Dual N1 Exhaust
-Blitz Power Meter I-D
-Corksport Type II front spoiler
-KSP Headlight cover
-Super ADVAN SA3R's
That's all for now, not quite as impressive as BOOSTD7's, I know, but I'm bored too...
Old Jul 31, 2002 | 06:47 PM
Angel Guard Racing Team's Avatar
How abot this?
1994 FD Intake and Exhaust ported engine
Jay-Tech intahe manifold
T-72 Turbonetics Turbo
Turbonetics Race Gate
Turbonetics Blow Off Valve
Custom made exhaust manifold
Haltech F9-8
8-1750 cc alcohol injectors
2 Weldon Fuel Pumps
2 Mallory Fuel Pressure regulators
G-Force Tranny
Ford 9 inch rear end
Methanol in the gas tank
No intercooler
NO NOS
Stock Cooling Fan
Stock Radiator
First gen Ignition system
MSD Blaster 2 coils
A very heavy full metal 1980 Mazda RX-7
8:32 @ 160 MPH 1/4 mile
OK I cheated that is our drag car
I could not stay quiet after all those mouth watering mods
Old Jul 31, 2002 | 06:50 PM
RiceRocket's Avatar
Livin loud like TIMMAAAYY
i can;t remember all my mods. and i don;t have half as many as you guys
Old Jul 31, 2002 | 08:40 PM
RETed's Avatar
You guys need to make a webpage with all the mods...
http://fc3s-pro.com/PROJECTS/myfc.html
-Ted
Old Jul 31, 2002 | 09:39 PM
AreExSeven's Avatar
Huh?
Wow. Pull this one from the dead? Funny, his target date was Sept 8, and it still isn't done
Old Jul 31, 2002 | 10:58 PM
darkwaveboi's Avatar
Need donor car in Fairfax
yeah, where the **** DO you guys get all your money
Old Aug 1, 2002 | 09:34 PM
We started with the car about 5 years ago it was a 1980 12A turbo carbureted RX-7 and ran 10:4's 100% street. Then we started putting money into it very slowly. After making the car go 8:32 we finally found a sponsor called ANGEL GUARD (after us putting all the money into it). Angel Guard is a locally made car care product like Armor All only it makes the tires a hell of a lot shinnier, it sells pretty good here. The sponsor pays for everything that gets broken (tranny, turbo etc).
Old Aug 1, 2002 | 10:09 PM
Wankel Traitor
Lets see if I can remember all mine:
S5 Jspec
Ported wastegate
TB mod
emissions blocked off
removed airpump
ThunderFabrications 3" dp/mp
Corksport single 3" catback
Greddy EGT
Autometer Boost
Autometer dual pod
Jacobs 8.5mm silicone wires
Tokico springs
KYB-AGX struts
Ractive strutbar
HoseTechniques silicone hoses
Walbro 255lph fuel pump
APEX'i S-AFC
Knightsports FCD
ACT Xtreme clutch
Stainless steel clutchline
17" Advan 5 (replicas)
Kuhmo 712's
Blitz BOV
Coming soon:
Brembo rotors
Hawk HPS pads
Suspension techniques swaybars
NPR (or similar) FMIC
upgraded hybrid turbo
injectors, 720cc X4
K2RD rear camber links
stainless steel brakelines
Mazda Factory A/C
Jameson
Old Aug 2, 2002 | 12:21 AM
angel guard: thats some cool ****. What would you reccomend doing going about getting sponsored once you have a car that is worthy
Old Aug 2, 2002 | 01:20 AM
BoostedRotors's Avatar
I HATE sleepy eyes
My list is getting long, I hope to one day have a list like that!! Gonna be a monster from what I can tell...Keep us posted!!
Old Aug 3, 2002 | 02:13 AM
Man... It is ******* HARD getting a sponsor.
Coochas
44
Nov 5, 2019 11:08 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
