Mazda fuel filter or aftermarket?
Old Aug 15, 2001 | 07:04 AM
turboedRX-7's Avatar
Hey guys, I think its past time to get a new fuel filter so any thoughts on staying with the Mazda part or would any auto parts store have a good enough one? Do they have differing fuel rates? Thanks & happy motoring!
Old Aug 15, 2001 | 09:33 AM
t_mak@mail.plymouth.edu's Avatar
Mazda, that's unless you want to run into not enough fuel pressure problem that I ran into with FRAM
Old Aug 15, 2001 | 10:08 AM
vaughnc's Avatar
knowledge junkie
Don't forget the fuel strainer in the gas tank. At least drop the tank and see if it's got junk all over it.
Old Aug 15, 2001 | 10:50 AM
Samps's Avatar
what the hell is the fuel stainer? I have spent a year working on and researching the 7 and this is the first I've heard of it. PLEASE EXPLAIN
Old Aug 15, 2001 | 11:17 AM
Speaking about that, where can i get a replacement filter for that one on top of the fuel pump?
Old Aug 15, 2001 | 11:48 AM
vaughnc's Avatar
knowledge junkie
You know how your suppose to drain the tank every 100K or so, the fuel strainer keep those larger particles from going through the fuel pump and into your engine.
I was thinking it was before the fuel pump. You might also want to replace the gasket as well while the tanks down.
Old Aug 15, 2001 | 05:21 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
I had excellent results with aftermarket from a local Kragen parts store.
The Fuel pump filter is, I assume, is the screen box around the bottom of the fuel pump assembly. If it is dirty, then you probably have a bigger problem with tank sediments. You should probably pull the whole tank (Not that tough, two bolts for the support straps and disconnect the filler hose connecter and pump) and have it cleaned out at your local radiator shop.
Related, I HIGHLY endorse you pull your injectors and ship them to RC Engineering (www.rceng.com) and have them back flushed and tuned. Only costs $20 each and you'll be beyond surprised what a difference in performance you'll get as a result. It should also fix a common hard starting problem caused by drippy injectors (alternative to Mazdatrix's H-valve for that problem).
Old Aug 16, 2001 | 12:21 AM
Dak's Avatar
Dak
Information Regurgitator
I have a purolator on my car it seems to work fine.Actually it is about time to replace it.
Old Aug 16, 2001 | 06:48 AM
Thanks guys! I don't have the time now to pull the tank or have the injectors sent out for cleaning, as my "88 T2" is my daily driver. But one step at a time I guess.
Happy motoring!
Queppa
Nov 18, 2024 03:47 AM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
