where to hook up the A/F gauge power wire
Old Aug 15, 2001 | 01:49 AM
sevenzoom's Avatar
i was wonderin where do u guys hook up ur A/F gauge power wire? I try to hook my wire wit the temp power one to a engine fuse in the car and it make my O2 sensor volt went up to 4.59v which suppose to be only at 0.03v. So please hook me up wit info on this please. Thanks alot
Old Aug 15, 2001 | 04:47 AM
Merciless's Avatar
The Love Below!!!
i think you tap the black wiring from the 16-wire connector from the ECU....
Old Aug 15, 2001 | 10:55 AM
evot23's Avatar
Classy
does the power wire go there (to ecu) or does the sensor wire?
Old Aug 15, 2001 | 11:14 AM
puma's Avatar
canadian monster
the wire to the sensor goes to the black wire on the ECU. You can take your 12V right on the ECU or on the fuse relay thing under the dash if you look under, right above the pedals. Any 12V standard is good. Even the one from the radio or anything else.
puma
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
