T-78 A/R information
Old Jan 30, 2003 | 08:26 PM
teachermechanic's Avatar
Hi everybody, i need this information: All the Greddy T78 have the same spect ( a/r and dimensions compressor and turbine ) ?
Thanks
Old Jan 30, 2003 | 08:43 PM
allrotor93's Avatar
yeah
Old Jan 31, 2003 | 04:13 PM
swordfish's Avatar
Uh. No.
You can get the turbine housing as a 17cm (Supra setup) or a 22cm (Rotary setup). However, they only offer one config for the compressor and turbine wheels.
jeff
Old Jan 31, 2003 | 07:19 PM
setzep's Avatar
Originally posted by swordfish
Uh. No.
jeff
On my TD07 there is a 17cm turbine housing. If you were to compare this to a Garrett p-trim turbine family, what A/R would it be close to? .84? 1.00? 1.15?
Thanks.
Old Jan 31, 2003 | 10:43 PM
swordfish's Avatar
My guess, is that it's closest in size to the .84. I'm not 100% sure though. The P trim wheel and the T78 turbine are nearly the same size.
P Trim Exducer: 64.6mm Major Diameter: 74.2mm
T78 Exducer: 65mm Major Diameter: 74mm
jeff
Old Jan 31, 2003 | 10:59 PM
T78
Thanks, but if i buy T78 for make 400rwhp at 15 or 16lbs on 13btt street port . What is the spect i need?
An what size of wastegate?
Old Jan 31, 2003 | 11:30 PM
swordfish's Avatar
If you are buying a kit, then the turbo will be the propoer size for your application. IE a greddy T78 kit from a reputable vendor. I posted the above info just incase you were thinking of buying a T78 (turbo only) that someone has for sale.
jeff
Old Feb 1, 2003 | 08:06 AM
allrotor93's Avatar
the only reason that i said yes was about a month ago i bought just the turbo and called greddy to ask them if the turbos were the same and they said yes. sorry for the runon sentence. i sold that turbo and then just bought the kit. sorry greddy was wrong.
Old Feb 1, 2003 | 12:10 PM
setzep's Avatar
jeff
Ahh hell... I was hoping you weren't going to say .84, Kinda small
cto_2
19
May 8, 2018 08:15 AM
Sh00bs
Oct 1, 2015 11:57 PM
