12A, 13B, intake manifolds. Different?
Old Jan 29, 2003 | 10:26 PM
pvc's Avatar
pvc
Not a registered voter
Does anyone know what the difference is?
I'm not talking about stock, but if you were buying a sidedraft manifold.
I bought a manifold that the seller told me was a 13B manifold. A 4-port. When I got a 12A manifold for my car, they looked exactly the same.
Old Jan 29, 2003 | 10:32 PM
RotorMotorDriver's Avatar
Seven Is Coming
I bet the 13B manifold is wider because of the wider rotor housings. Check where the holes in the manifolds would hit.
~T.J.
Old Jan 29, 2003 | 10:47 PM
mar3's Avatar
Administrator
Even if you're not talking about stock manifolds, this link will show the differences as the block sees them and should provide a clue as to why it won't work...
Intake Manifold Differences
Oops...my bad...the link concerns only 13B manifolds....
Old Jan 30, 2003 | 12:16 AM
pvc's Avatar
pvc
That's what I thought, because I put both the 12A manifold and the 13B one together and they are the same size. Maybe this seller guy was wrong.
Old Jan 30, 2003 | 01:21 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Sounds like your seller may not have known what he was talking about. BTW, there is an adapter to mate a 12A manifold to a 13B block, I think Racing Bleat sells 'em, or at least they used to. I have a friend who used one on his 13b converted RX3 wagon and it worked well for him.
Old Jan 30, 2003 | 01:36 PM
Sammymatik's Avatar
How much does that adapter plate cost? I was figuring I could just have one made from some steel at a local machine shop. Just use the gaskets as a template.
Old Jan 30, 2003 | 01:55 PM
Wankelguy's Avatar
I'm not sure what they cost, I'm pretty sure they were aluminum, though. It wouldn't be hard to have one made by any competent machinist. It does add a little length to the runners, which is worth consideration, as that will affect the power curve somewhat.
