T04b compressor wheel and housing.
Old Jan 27, 2003 | 10:17 AM
darkwaveboi's Avatar
Need donor car in Fairfax
Would a turbonetics T04b standard shaft 60-1 compressor wheel with matching 4" inlet housing work with a stock turbine and internals? would a new backing plate be needed as well?
Old Jan 27, 2003 | 01:47 PM
rx7_turbo2's Avatar
Professor D.P
I am not certain but I believe a new back plate is needed for the To4b housing.
Old Jan 27, 2003 | 02:51 PM
alrite..well..let me elaborate on my story.
I bought a "good" turbo that the turbine housing is more or less toast (can be fixed..but more money than i'd want to spend).
Is there any way to use the stock center (oil/coolant lines go into it) and upgrade the turbine/compressor and housing to T04b standards.
I paid 300 for this turbo..so im tryng to weigh my options to USE it while upgrading it at the same time.
Any recommendations short of just saying screw it and losing my 300?
Thanks.
Jeff
(BNR says they can do the stage 4 hybrid and put on a different turbine housing for 170 bux..ouch!
Old Jan 28, 2003 | 11:58 PM
spoolin's Avatar
man, i just bought a brand new garrett turbo with a 1.15 divided turbine housing and a .60 compressor housing( i told him i wanted a .70 compressor housing per rice racings specs.....the dealer's fault- i pick up the .70 tomorrow) and he upgraded to the garrett 17 wheel (60 mm) for $525.00. i'll post a pic with .60 housing--has a 4" opening on it.
Old Jan 29, 2003 | 12:19 AM
spoolin's Avatar
here ya go
Old Jan 29, 2003 | 12:25 AM
spoolin's Avatar
another
Old Jan 29, 2003 | 12:31 AM
spoolin's Avatar
one more
Old Jan 29, 2003 | 12:36 AM
spoolin's Avatar
anyway, to answer your question, yes, you will have to get a new back plate....at least i had to from the original one that had the smaller wheel.
Old Jan 29, 2003 | 12:42 AM
Sinful7's Avatar
what a score. spoolin what kind of hp would that turbo give you?
Old Jan 29, 2003 | 12:44 AM
Sinful7's Avatar
between 400-450?
Old Jan 29, 2003 | 09:07 AM
spoolin's Avatar
Originally posted by Sinful7
between 400-450?
that's where i told peter (rice racing) i wanted to be and he gave me those specs on the comp and turbine housings with a 60-1
