Stock 20B Fuel Rail Question
Old Jan 26, 2003 | 09:40 PM
Turbo 3's Avatar
Safety Guy
On the primary fuel rail, on the leading edge towards the front of the motor, there is a green electrical quick-connect clip for a sensor that is plumbed into the fuel rail. My question is: is this sensor the stock fuel pressure sensor or is it for fuel temperature?
I'm currently using an external fuel pressure regulator to plumb in my fuel pressure sensor but if the other sensor is available to watch fuel temperature...? It'd be nice to see how fuel temps affect other things as well.
Old Jan 27, 2003 | 12:19 AM
j9fd3s's Avatar
Community Builder
its fuel temp like the fd
mike
Old Jan 27, 2003 | 06:11 PM
Turbo 3's Avatar
Safety Guy
Great, thanks Mike...next question.
Is anyone bothering to monitor this parameter outside the stock ECU and since only one of us is even using the stock ecu anyhow...
If so, what gauge are you using because I don't believe that it is common (at least I haven't found it on Jeg's or Summit)?
Old Jan 27, 2003 | 10:02 PM
j9fd3s's Avatar
Community Builder
that sensor i think reads the same as the stock coolant temp sensors, well its in the fd shop manual
mike
Old Jan 29, 2003 | 06:19 PM
Turbo 3's Avatar
Safety Guy
The problem I was finding was being able to find a gauge that would read temps between 40-200 Deg. F. The only one I know of is intake air temp. But then you'd have to pull the face of the gauge off and put your own markings on. Either that or go digital with Dakota Gauges...
Old Jan 29, 2003 | 11:31 PM
j9fd3s's Avatar
Community Builder
the greddy guages only say temp? i was figureing you just wanted to see what it did
mike
Old Jan 30, 2003 | 04:56 PM
Turbo 3's Avatar
Safety Guy
Greddy? No, I was referring to Autometer but my fault for not saying so. Yes...I just wanted to monitor it for fun.
Old Jan 30, 2003 | 06:19 PM
j9fd3s's Avatar
Community Builder
haha, i was being confusing too. i meant to say that my greddy guages just say temp and thats it.
it would be interesting to see what it does
mike
astrum
24
Nov 15, 2017 08:44 AM
