Rear End Vibration
Old Jan 20, 2003 | 02:04 PM
JOEYRX7's Avatar
Angry Rear End Vibration
86 RX7 HELP I HAVE INTERMITTEN VIB FROM 10 MPH UP ABOUT 30 % OF THE TIME. NEVER OCCURS WHILE IN MOTION , ONLY AFTER I STOP IE STOP SIGN/ LIGHT. ALL BUSHINGS IN REAR ARE OK TIRES AND WHEELS ARE OK. ANY THOUGHT OR IDEAS
Old Jan 22, 2003 | 01:24 PM
ermin277's Avatar
have you checked all the u-joints from the tranny back? Try to move the driveshaft by hand with no load on the shaft and see if you can feel it move. a bad joint is usually easy to feel.
Old Jan 24, 2003 | 12:39 PM
JOEYRX7's Avatar
YES ALL THE JOINTS SEEM TIGHT THE PROBLEM NEVER OCCURS WHILE IN MOTION . WILL STOP AND START WHILE AT A STOP. I RACKED IT PUT IT IN GEAR AND NEVER COULD GET IT TO OCCUR. SO CONFUSING , IM THINKING OF JUST BUYING A USED DRIVE SHAFT BUT IT LOOKS LIKE A BIATCH TO PUT IT IN . THANKS
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
