Help locating front pad M-springs part number
Old Jan 19, 2003 | 11:15 PM
reza's Avatar
Help! locating front pad M-springs/clips part number
I found out today that the M spring is missing on the left front ones.
Does anyone knows the part number of this for 1993 RX-7.
I look at parts number PDF, and it only mention pin. I need the spring not pin. This is the part number in question: FD01-33-696
I also think that springs are included in the pad set # FDZ3-33-23Z
I just want the spring, don't want to spend >$50 for pad I don't need.
Anyone knows the part number for those springs?
Thanks,
Reza
PS: I checked thru the Part number PDF on http://www.iluvmyrx7.com
Old Jan 20, 2003 | 12:04 AM
j9fd3s's Avatar
Community Builder
the hardware kit is something like fd3z-33-29z, you cant look it up its not in the fische
mike
Old Jan 20, 2003 | 12:55 AM
reza's Avatar
i tried this on the mazdamotorsports website.
Parts not found.
Where can I look this thing up?
Reza
Old Jan 20, 2003 | 12:58 AM
jr's Avatar
jr
Call Brian at www.mazdaformance.com and he should be able to order it for you. I got an aftermarket brake hardware kit (I believe it was from Bendix) from my local Pep Boys when I lost one of the clips. It's held up fine so far.
Old Jan 20, 2003 | 01:04 AM
reza's Avatar
Jr,
So its available localy thru Pep Boys too?
Cool. I am gonna drop by tommorow. What do I tell them? Would they know?
Thanks
Reza
Old Jan 20, 2003 | 01:17 AM
jr's Avatar
jr
Ask the guy at the part counter for the front brake hardware kit for a 93-95 Mazda RX-7. I think it was ~$15 and came with the pins and springs for one side.
Old Jan 20, 2003 | 02:13 AM
reza's Avatar
hmm...I saw the hardware kit at Mazda Formance website(http://www.mazdaformance.com/Merchan...egory_Code=420).
Apparently the hardware kit consist of: pins, and one spring that hold the pins in place.
What I need is the big and small M-springs that hold the brake pads in place. I saw this packaged together with the brake pads on Mazda Formance Website (http://www.mazdaformance.com/Merchan...egory_Code=420).
How can I just get the springs, I am installing HP+ pads.
Old Jan 20, 2003 | 04:25 PM
reza's Avatar
ttt
josef 91 vert
23
Sep 3, 2015 11:20 AM
Marty RE
Aug 29, 2015 07:51 AM
04G35S
Aug 14, 2015 07:31 AM
